Will this turbo work on a 5.0? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 07-28-2005, 01:01 AM Thread Starter
I have a garret A/R .50 with an aprox. 50mm inlet
Will it work on a stock 5.0, or it is small. i want to have 8-10psi on it
Mesarina is offline
post #2 of 7 Old 07-28-2005, 01:05 AM
Need to measure the compressor wheel as well. With that info it could be a T3 turbo, but i'd assume its a T04 turbo.
mfpmax is offline
post #3 of 7 Old 08-01-2005, 09:11 PM Thread Starter
My friend says it is an garret AR15 which is a little bigger than a T04
Will it work?
Mesarina is offline
post #4 of 7 Old 08-09-2005, 10:46 PM Thread Starter
Any ideas??
Mesarina is offline
post #5 of 7 Old 08-10-2005, 02:19 PM
Sounds very small...
My T66 has ~75mm inlet. I also have a 0.81 A/R p-trim turbine.
Cld12pk2go is offline
post #6 of 7 Old 08-10-2005, 05:31 PM
A .50 A/R exhaust housing is pretty small. Might be okay in a twin setup (depending on the compressor) but you'll choke that 5.0 off with a turbine housing that small in a single setup.
turbotko is offline
post #7 of 7 Old 08-10-2005, 10:49 PM
i totally agree with turbotko.......to small for a single set up..
wyominghotwheels is offline
