Billet Steel or Billet Aluminum Flywheel for my new turbo set up???? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 07-26-2005, 10:42 PM Thread Starter
well, ive been asking alot of questions lately pertaining to my new Turbo setup.....i have decided to go with a Proshifted Tremec TKO, i will be buying either a Spec stage 5 clutch or a Clutchmasters 8.5" racing clutch, but what flywheel....either clutch can use either flywheel....what do ya'll think
RGVBadBoy is offline
post #2 of 9 Old 07-26-2005, 11:06 PM
if you have the cash bro, go with the aluminum.............doesn't get as hot as steel........just my .o2
wyominghotwheels is offline
post #3 of 9 Old 07-27-2005, 12:18 AM Thread Starter
thank you.... i was leaning toward aluminum.....another question, will the Aluminum create as much boost for my launch as a steel wheel would, i know that the aluminum is much lighter as far as rotating weight is concerned and you need to launch at higher RPM for this reason....
post #4 of 9 Old 07-27-2005, 10:46 AM
I do not know if the weight of the flywheel will play a huge part in building up boost against a 2-step for launching. I'd guess if it did you could compensate things via some timing changes when on the 2 step.
post #5 of 9 Old 07-27-2005, 09:44 PM
i totally agree with snipe on this.........
post #6 of 9 Old 07-28-2005, 12:52 PM Thread Starter
then Aluminum it is....i think im gonna get that QuarterMasters 8.5" cluthc and flywheel setup, along with their bell housing....the clutch and flywheel are only supposed to weigh 20lbs apposed to stocks 54lbs....pretty cool in my book...
my drivetrain will consist of......Tremec Proshifted TKO, QuarterMasters steel scattershield bellhousing, QuarterMasters 8.5" racing clutch and billet aluminum flywheel, FRPP Aluminum driveshaft, hardened U Joints, Pro5.0 shifter, line lock, Moser 31spline axles, powertrax differential....i hope my turbo set up doesnt break anything....
post #7 of 9 Old 07-30-2005, 04:36 AM
that is awesome...........wish i had the money to go aluminum.........man, that is gonna be sweet.
post #8 of 9 Old 07-30-2005, 11:27 AM Thread Starter
thank you, i dont get to drive it much, it will see SOME street duty, but only to keep my battery charged its gonna keep the A/C mainly just to say that i have it.....i'm hoping the car is fast
post #9 of 9 Old 08-01-2005, 01:06 PM
Quatermaster = the Shiznit
very good stuff and they really reduce the MOI (which is what matters, not really the weight) on their clutch/flywheels..
Cld12pk2go is offline
