DIY TURBO QUESTIONS/SUGGESTIONS!!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 07-14-2005, 10:18 PM Thread Starter
1991stang50's Avatar
BEGINNING WORK ON A SINGLE TURBO SETUP ON AN 87 GT. SINGLE UNIT MOUNTED ON PS. HAVE NO PROBLEMS WITH MOUNTING, TUBING, FUEL, TUNE, ETC. BUT, I AM IN QUESTION ABOUT THE USE OF A EXTERNAL WASTEGATE, AND BLOW OFF VALVE. FIRST OFF, WE ARE BUILDING A MILD SETUP FOR A STREET/SHOW USE ONLY. WE ARE NOT LOOKING TO BOOST ANYMORE THAN 8-10 PSI. AS FAR AS THE SETUP GOES, WHERE IS THE BEST POSITION TO MOUNT THE WASTEGATE AND BLOWOFF? DO BOTH HAVE TO BE USED? ANY TIPS AND POINTERS WOULD BE A HUGE HELP. PICS ARE WELCOME. FEEL FREE TO GIVE ME ANY AND ALL OPINIONS!!! THANKS CORRAL!!!
1991stang50 is offline
post #2 of 7 Old 07-14-2005, 11:06 PM
Turbomustangs.com has many pics of where various people mount them in their setups, and i think there are some here too, as far as using both, its a good idea, wastegates limit the boost you run, and bov deals with compressor surge, which is a bad thing.
91 lx hatch. Performer heads, Performer 2 intake, 1.7rrs, tfs 1 cam, pullied a-trim with power pipe, long tubes, orx pipe, and a magnaflow catback, [email protected] on 17" Nittos.
MediumRed91LX is offline
post #3 of 7 Old 07-14-2005, 11:12 PM Thread Starter
so does the wastgate go before the turbo, and blowoff after the turbo? thanks!!!
post #4 of 7 Old 07-14-2005, 11:52 PM
flashman's Avatar
yes and yes but the bov needs to be ran with a blow-thru mass air meter
89 coupe- some parts
best time-11.67
best mph-120.57
best 60 ft-1.63
flashman is offline
post #5 of 7 Old 07-15-2005, 01:14 AM
The FAQ's pages in the forums on turbomustangs should get you pointed in the right direction, There are very few things not touched on in there.
-Jason
db1994 is offline
post #6 of 7 Old 07-15-2005, 03:06 AM Thread Starter
THANKS GUYS.....KEEP THE INFO COMING......
post #7 of 7 Old 08-14-2005, 04:11 AM
Use a TiAL Sport 38mm Wastgate with a small blue spring. That will give you around 8 psi. You'll want the WG mounted in a way to give smooth flow from the hot side tubing into the WG preferably less then a 90* turn into the WG tube. Mines about a 45* angle. Also use a TiAL Sport 50mm BOV. I have my WG a few inches before the turbine in the hot side merge pipe and my BOV a few inches after the compressor outlet before the MAF.
BRIAN
95silverstallion is offline
