Please help me get my JYTT to work!! Im getting frustrated - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 19 Old 06-21-2005, 11:43 PM Thread Starter
Im getting really annoyed now,
Ive done everything I thought of and still no dice,
The car shudders, backfires, and wont clean rev,
If anyone remembers my other threads It seems I bought 38# injectors thinking they were 42#,
I now have 42# injectors and fitted them today along with a Pro-M Univeral blow thru.
Can still wont run
heres the problems,
The car wont rev properly, It shudders under boost and my boost gauge goes up and down from 5 to 8psi to 5 to 8 to 10 etc, and the whole car rocks like crazy,
The fuel rail or injectors are making a screaming noise, like a slipping belt, but its the injectors, I can also hear a very loud hissing that seems to be coming from the fuel rail, alomost sounds like a vacuum leak,
Now heres my setup,
302 TT,
2 Garrett T3's with external wastegates controed by a boost valve,
255 LPH Walbro
42# ford racing injectors
42# blow thru ProM Universal
stock fuel rail and regulator
10* timing
Now with that formular the car would run?
why wont mine?
also the check engine light comes on all the time, then goes off, then comes on, the car wont run, sometimes it wont start again,
also the turbos make a weird noise when you let off the gas, sounds like boooooooooooooooooo,
really weird, never heard that
Please help me fix this, I feel so close yet so far,
Insertc0in is offline
post #2 of 19 Old 06-22-2005, 09:10 AM
First of all, take the spout out and set your timming to 18-19 deg. This will eliminate timming isssues. Second, what type of wastegates do you have? I have a Tial 44mm and when I hooked it up wrong (vacuums) the car was having odd issues. How does the car run at idle? Will it free rev (no boost) or does it break up?
What spring is in the wastegate? What psi?
Turbo5oh is offline
post #3 of 19 Old 06-22-2005, 10:30 AM Thread Starter
its an actuator rail type wastegate
and is it safe to run the car with the spout out?
post #4 of 19 Old 06-22-2005, 10:39 AM
Yes it's safe, taking the spout out locks the timming down it does not let the eec make changes. Is there vacuum lines to the wastegate(s)? do you have a blow off valve?
Turbo5oh is offline
post #5 of 19 Old 06-22-2005, 11:20 AM Thread Starter
yes acuum lines to the wastegates and I do have a BOV,
Im starting to think it my MAF,
Could I run a lightning MAF as a blow thru?
ive heard it does actually work
post #6 of 19 Old 06-22-2005, 11:55 AM
No, a Lightning MAF is different, you need a chip burnt for it.
Turbo5oh is offline
post #7 of 19 Old 06-22-2005, 05:48 PM
Erich's Avatar
Is your bov AFTER the MAF? If so, you are losing metered air. That will make the car run screwy.
Erich
Erich is offline
post #8 of 19 Old 06-22-2005, 06:19 PM Thread Starter
no BOV is before the MAF
still wont run
post #9 of 19 Old 06-22-2005, 06:57 PM
what is your car's idle rpm right now?
Couple things i would do first:
1st, lock your timing as suggested above.
2nd, take a .010 feeler gauge and adjust your throttle body plate, after you set that to a slight drag, go into the car, turn the key to the power side, but don't start the car and set your tps, stick a pin in the green wire and ground out where ever and set your tps to .096 to .098. Then start the car and see how it idles.....
3rd, be sure your vacuum lines on your wastegates are on the sides and not on the top, unless you have a digital boost controller......
4th,Adjust your wastegates almost all the way down, don't worry to much about the amount of boost right now because you are trying to tune the motor so that it will run.
5th, on your bov be sure you screw it downward almost as far as it will go......
6th, be sure that your wastegate vacuum lines and your bov are on seperate sources.
7th, check your fuel pressure.....with the car running at idle, remove your vacuum line and install a little bolt or something in the end of it so it doesn't leak......then adjust your fuel pressure to 38 or 39 #'s..........
take the car for a spin and see if you still have shudder and back firing.......i will try to get back to your post a.s.a.p.
wyominghotwheels is offline
post #10 of 19 Old 06-22-2005, 07:27 PM
also, before i forget, what are your sparkplugs gapped too? should be between .32 and .35 hotwheels
post #11 of 19 Old 06-22-2005, 11:06 PM Thread Starter
yes Im using autolite 3923's at .35 gap
Im going to yry those things tomorrow see if it runs better
post #12 of 19 Old 06-23-2005, 09:02 AM
let me know how it goes............later, hotwheels
post #13 of 19 Old 06-24-2005, 08:56 AM
STANGFREEK94's Avatar
Trader Feedback: (27)
Sound like the fuel pressure regulator. The check engine light is prolly from the surging, the maf is prolly freaking out, throwing a light. What codes are you getting? Do you have a fuel pressure gauge? What is it doing? Where is the fuel pressure at an idle? The boost is going up and down, cause it is trying to accelerate, but can't. The noise from the turbos? I have no idea about that. How is the oil pressure?
1994, 347, 78mm, alot, NO-you can't!
STANGFREEK94 is offline
post #14 of 19 Old 06-24-2005, 01:16 PM
Vacuum leaks have been known around fule rails, and will make a car run like open ass. Im no expert on turbo cars so I have no advice to give you here. If you think your hearing a vacuum leak from the rails, then you most likely are. did you put the injectors in dry, or did you add some sort of lubricant to the orings to help them slip in. I usualy do that to keep them from ripping especialy in aftermarket intakes where the machining process sometimes varys from intake to intake. I usualy hold my rails down tight with one hand and tighten them with the other just to assure no leaks. Wish we were there in person to help bud.
Steve
post #15 of 19 Old 06-24-2005, 03:57 PM Thread Starter
yeah really sounds like the fuel rails hissing,
then If I push down on the rail the car dies,
DAM this car to hell
post #16 of 19 Old 06-27-2005, 10:18 PM
Its something to do with your fuel rails, injectors or something in that area. If you push down on the rail and the car dies then something is wrong. I would take the rail off and see if an o ring is busted on one of the injectors.
CP5696 is offline
post #17 of 19 Old 07-02-2005, 12:23 AM
I had the same problem. It was a cracked o ring, replace the o rings and uut it back in. I would seat the injectors in the manifold first then use a rubber malet to gelty tabe the rail into place on the injectors. Press down on the rail as you tighten it down, as the bolt you are driving is will want to raise the rails up. Good luck!
jerrydaugherty is offline
post #18 of 19 Old 07-16-2005, 01:15 PM
SHaFT7's Avatar
when we installed injectors i found it was MUCH easier to put all the injectors in the rail first, then lay the rail down on the intake, and one by one, pop each injector into the intake port
Ralph - Armchair politician: I may not be a market analyst, but I DID stay at a Holiday Inn Express last night.
91 GT - SOLD missed!
02 ZX-6E - SOLD
04 Acura TL - trans cooler
SHaFT7 is offline
post #19 of 19 Old 07-16-2005, 06:34 PM
plus put a dab of oil on the o ring of each injector before you install them
what kind of engine management are you using also?
1 bad Mustang, 2 slow Z28's, and a Sierra crewcab for the groceries.
Racenrik is offline
