turbo help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 06-19-2005, 01:15 PM Thread Starter
turbo help
I'm sure ya'll get this question all the time but i'm thinkin of turbocharging my 91 5.0 aod and i was wanting to know what is the best setup to run around 10 psi, like intake manifold,gears,etc. any help would be appreciated thanks keegan p.s. i want the car to be a highway and quarter mile car
mustang98 is offline
post #2 of 3 Old 06-19-2005, 06:53 PM
Keep everything the way it came from the factory. Call hellion or b&g and put yourself a turbo kit together. See if you have the will-power to keep the boost low enough not to split your stock block.
70 turbo fastback
73 kickass bronco.
braxton357 is offline
post #3 of 3 Old 06-20-2005, 04:27 PM
I've read, and browsed alot through here and turbomustangs, and from what i've seen there is no real 'best' combo, but if you plan on building a motor for it, alot of people use twisted wedge heads and a small cam (e cam is popular in mild setups) 2.73s, 3.08s, and 3.27s are popular gear ratios. And like braxton said, get ahold of hellion or b&g they can both help you out alot more than I can.
91 lx hatch. Performer heads, Performer 2 intake, 1.7rrs, tfs 1 cam, pullied a-trim with power pipe, long tubes, orx pipe, and a magnaflow catback, [email protected] on 17" Nittos.
MediumRed91LX is offline
