maximum compression ratio - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 06-17-2005, 10:46 AM Thread Starter
91StangCoupe's Avatar
I'm going turbo. I have Ross 99502 pistons, which I think is about 10 to 10.5:1. What's the max you would run? I'm looking at about 500rwhp with a set of TW heads / carb'd 306. Maybe 8-10 psi range.
If these would not work, what piston would be best for twisted wedge heads?
1991 Blow-thru turbo Coupe 1.41 60ft - 6.71 @ 105 1/8 mile - SOLD
1989 GT - SOLD
1990 LX - Being prepped for paint
91StangCoupe is offline
post #2 of 6 Old 06-17-2005, 06:37 PM
If you are going to be intercooled, you should be able to get away with 8-10.
Just tune it imediately.
92 GT
[Pro Turbo Kits T-66]
[X2C v1.0 TKO]
04 Lightning
[Bone Stock]
92FivePointSlow is offline
post #3 of 6 Old 06-18-2005, 01:00 PM
Well, you're gettin' up there in compression. Ideally, you'd want to lower it a bit.
But if you want to use those pistons, I'd just mix in some high octane gas in there and let her rip.
mustanggreg is offline
post #4 of 6 Old 06-18-2005, 08:22 PM
i totally agree.......
wyominghotwheels is offline
post #5 of 6 Old 06-20-2005, 10:27 PM
Rods's Avatar
iv ran up to 15lbs with 10.0 with TW heads on 93 pump keep the timing down and yr find
93lx
01 3500 street/pull truck
Rods is offline
post #6 of 6 Old 06-21-2005, 08:43 AM Thread Starter
Sweet. Just what I wanted to hear. I've sort of changed my plans a little. Instead of the 306, I'm just going to put together a 351. I can achieve my 500-550rwhp with less boost and be in even better shape on the CR.
1989 GT - SOLD
