help hp turbo kit does not fit my heads - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 06-17-2005, 01:40 AM Thread Starter
can anybody tell me where to get or who to call to get some adapter plates .....to go from 2" sbf bolt pattern to the 3" bolt pattern found on dart and afr 225 heads for exaust....thanks help is needed bought hp turbo kit and headers have 3" inch pattern and my tfs heads have 2" pattern..
whitecnvrt1000 is offline
post #2 of 13 Old 06-17-2005, 01:59 AM Thread Starter
ttt anyone
post #3 of 13 Old 06-17-2005, 10:13 AM
Which TFS head do you have? I have a set of Darts and a set of TWR heads and their patterns are not the same. I only ask because I hate to lead you to the wrong adapters. TEA used to sell adapters to run a standard SBF header on a TWR head and actually I think TFS even sold adapters for it as well.
post #4 of 13 Old 06-18-2005, 12:15 PM Thread Starter
the dart style pattern. 3" in a line
post #5 of 13 Old 06-18-2005, 01:34 PM
What Dart head is 3" inline? I just measured my Dart Sr heads and the outer pattern is bigger than 3" I just measured my TWR TFS heads and they are right at 3" using a tape measure so not 100%
post #6 of 13 Old 06-18-2005, 01:53 PM
Big Top GT's Avatar
Trader Feedback: (37)
I hate to point out the obvious but have you tried calling HP?
A
98 Cobra Coupe ~ Back to square one: no motor.
2006 Lotus Exige - 1.8 litres of Supercharged fury!!! SOLD!
Originally Posted by ATOMONKEY
If you don't want to take my word for it, maybe you'll believe the internet.
Big Top GT is offline
post #7 of 13 Old 06-20-2005, 08:11 PM Thread Starter
hp is no help they are 60 kits behind...need to go from normal sbf to dart or afr 205,225 bolt pattern does anybody know who sells adapter flanges for exhaust...tried all the big names so far no help.....
post #8 of 13 Old 06-20-2005, 08:14 PM
I would try Kooks.
1quick6 is offline
post #9 of 13 Old 06-20-2005, 08:16 PM
I mentioned TEA already, they sell the one for the 3" to normal. I think you are wrong using the Dart term because as I pointed out I measured my Darts and my TFS TWR heads and my Darts are bigger than 3". TFS I believe even sells adapters for their heads to work with standard heads as well. You do realize once you put in adapters you throw off your turbo kit some and might run into fitment issues with things like the crossover tube.
post #10 of 13 Old 06-21-2005, 12:13 PM
Exclamation
[QUOTE=snipe656]I mentioned TEA already, they sell the one for the 3" to normal. I think you are wrong using the Dart term because as I pointed out I measured my Darts and my TFS TWR heads and my Darts are bigger than 3". TFS I believe even sells adapters for their heads to work with standard heads as well. You do realize once you put in adapters you throw off your turbo kit some and might run into fitment issues with things like the crossover tube.[/QUOTE
I have the HP kit on my '89 5.0, and yes it may cause fitment issues. I would not worry about the cross over, however the header on the pass side may hit the inner fender.
I don't remember exactly how they look, but could you not weld shut the holes in the header flange and have them drilled for the proper bolt pattern?
Turbo5oh is offline
post #11 of 13 Old 06-21-2005, 02:06 PM
If you did that I do not think the tubes of on the flanges would line up well with the ports on the heads.
post #12 of 13 Old 06-26-2005, 01:52 PM
I bought some sub plates from kooks and theyre close to 100 bucks!
bradinwva is offline
post #13 of 13 Old 06-27-2005, 12:40 AM Thread Starter
does anybody have the number for TEA??
