What caen of header gasket and sparkplug i need? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 05-30-2005, 09:22 PM Thread Starter
Hey guys i'm almost ready to install my t44 kit and i want to know what caen of header gasket and sparkplugs should i use, also what price and where i can buy it. Thanks
-David
95lightning is offline
post #2 of 8 Old 06-02-2005, 08:29 AM
if it was me, spend a few buck's and buy some copper header gasket's.......i have tried 4 different types and the copper seem to last the longes........ as far as sparkplug's go, just go with a set that is 2 step's colder and gap them at .032.........you'll be good to go...........if you need any help, just get ahold of me at insanemustangs.com, i will gladly help guide you through your installation..........hotwheels
wyominghotwheels is offline
post #3 of 8 Old 06-02-2005, 08:30 PM
I don't even use em, just a smear of the high temp silicone, 2 steps colder on the plugs.
"The junkyard dog"
90 cpe w/ twin turbos
10.9 @125 bone stock motor w/13psi of intercooled, untuned
boost
ntrcptr90 is offline
post #4 of 8 Old 06-03-2005, 07:48 AM
Erich's Avatar
That high temp silicone works that well?? How about on a exhaust flange (the rounded type with a bell mouth on the tube)? I don't get a perfect seal there and I was thinking of using that silicone.
Erich
Erich is offline
post #5 of 8 Old 06-03-2005, 09:25 AM
High temp silicone. Works perfect with my HP kit.
Turbo5oh is offline
post #6 of 8 Old 06-04-2005, 10:33 AM
i tried the high temp, but my mac shorties that i use don't have the full flange and the fugger start's leaking really bad..........i found that the copper header gasket's for 19 bucks, solved that problem till i can build a new set of headers.....
hotwheels of www.insanemustangs.com
post #7 of 8 Old 06-04-2005, 10:39 AM
post #8 of 8 Old 06-08-2005, 12:22 AM
I too use high temp sealant and its worked well for me.
CP5696 is offline
