ysi trimvs 60mm turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 05-19-2005, 04:13 PM Thread Starter
wich one of these bad boys will post up some good numbers at 25 psi on either a 377 or a 4.6 dohc im in the middle of thinking of wich motor i wan to build but i know i want the ysi supercharger inles i can get more out of a small turbo or at least a singal turbo. im thinking of 780to1000 rwhp and thats just what i intend to do so will the 60 be enuf for that im going to intercool and methonal inject the turbo but the ysi ill just meth it. so what do u guys think about that. just let me have some opions i might go to a on step bigger turbo if someon will suggest one thanks
Saleencrazy is offline
post #2 of 9 Old 05-19-2005, 08:04 PM
Why don't you compare two power adders in the same range there champ? YSi is almost the size of two 60mm turbos.
I think you just need to do a lot mor ereading before you jump in and buy anything.
highschoolphenom is offline
post #3 of 9 Old 05-19-2005, 08:42 PM
Trader Feedback: (101)
I agree w/ HS pnenom. You aren't comparing two equal power adders. If you really want to make that kind of power than you might start looking into a 76GTS or something bigger.
papis408 is offline
post #4 of 9 Old 05-19-2005, 10:03 PM Thread Starter
okay im not a turbo guy i havent ever looked really thats y im asking totally new to this turbo stuff so what is compatibale with the t trim would that be a good comparison to the 60mm what do u think im looking around could someone just give me some specs on turbos please
post #5 of 9 Old 05-20-2005, 12:21 AM
T-trim is like PT67 comparable. YSi-trim is like GT42-76. 60mm turbo is like an S-trim.
Black 1991 Notchback
Grabber Blue 2012 GT - HID's, Brembos, Nav
Red Metallic 2011 F350 Lariat CCSB
1000HP is offline
post #6 of 9 Old 05-20-2005, 10:23 AM
Yeap, so just get a pair of S-trims and call it a day
post #7 of 9 Old 05-23-2005, 03:56 AM Thread Starter
well if i could i would run dual superchargers but ive never heard of or seen it done so i might half to get me a 90mm turbo so i dont half to worrie no more
post #8 of 9 Old 05-23-2005, 01:32 PM
I can tell you this,my car last year:ysi 24lbs=895rwhp
nothing in the motor changed except for a smaller cam and twin 61mm innovative turbos=1020rwhp @20lbs of boost thats 4 lbs less boost for more power,I would definitly suggest going turbos if its in the budget
sn95 cobra 347rblock T-56 twin turbo
f-304z heads,hydraulic roller
1075whp,[email protected]
[email][email protected]
danimal 95 is offline
post #9 of 9 Old 05-24-2005, 12:44 AM
Pro Stock John's Avatar
Might be in the budget.
Co-founder
1951 Mercury custom lead sled
2010 Camaro SS [email protected]
Pro Stock John is offline
