mass air for turbo set-up - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 05-09-2005, 12:15 AM Thread Starter
what type of mass air should i use for my twin turbo intercooled 10 psi 5,0 lx. I have 42, msd ,255 pump ,btm and stock engine. Should i get blow thru calibrated for 42,s, or just a 75mm mass air or what?Im also getting a chip burned
jacklx is offline
post #2 of 2 Old 05-15-2005, 06:54 PM
75mm will work fine..........i have basically the same set up and i am using a 92mm..........myself, i would look at minimum of an 80mm..............
hotwheels of insanemustangs
wyominghotwheels is offline
