twin turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 04-25-2005, 10:41 PM Thread Starter
Justin5.0's Avatar
twin turbo
I just orderd a ponydown.net kit and am just wondering if someone whos done a twin turbo kit can help me out with what ill need. I already have 1 turbo from a 88 auto turbo coupe, im planing on 42lb injectors. what else will i need? anyone ever have a setup like this on a stock motor? and how does it run? I would like to get this done in the next month. thanks for any help
1992 Gt twin t3/04s 500rwhp
1955 Chevy 210 454 coan 2800 stall 373s caltracs
Justin5.0 is offline
post #2 of 10 Old 04-26-2005, 09:37 AM
bjsstang03's Avatar
id rebuild the whole engine, or atleast put forged pistons in there. so you dont snap it in half with the boost your going to run, not sure of anything else hope someone else post.
brandon
bjsstang03 is offline
post #3 of 10 Old 04-26-2005, 11:24 AM
I'm interested in this kit also. What other turbo's can you run besides the Ford ones?-They're pretty rare in my area. I'm pretty sure his engine already has forged pistons and can be ran fine, as your not always in the boost like a supercharged car is.
stangluver43 is offline
post #4 of 10 Old 04-26-2005, 12:31 PM
bjsstang03's Avatar
your not always in boost, your under pressure, my bro has the NOVI2000 and doesnt really go into boost, but sometimes he does, man i like that SC you can here it whine when your crusing. you can go with any turbo you just have to fabricate the exhaust and such. like a junkyard turbo for instance i see that all the time, and the people just fab up the parts that they need for the turbo.
brandon
post #5 of 10 Old 04-26-2005, 01:16 PM
So the ponydown downpipes will bolt on to pretty much any junkyard T3 turbo but you just have to fab up your exhaust to match their downpipes? Thats not too bad.
post #6 of 10 Old 04-26-2005, 07:05 PM
i didnt say that but its a thought, any turbo will fit, you just have to fab up some stuff, not sure what stuff to fab i dont have a mustang or a turbo, LOL
brandon
Black 93GT, Single Precision 7675, 308 Mexican block, F cam, AFR 195's, 75mm TB, 1.7RR, 60's, BA5000 MA, Crane Hi-6, LX-92 Coil, S/N 95 Rails, Kirban FPR, 255 inline/255 intank, aluminum radiator, Countour Fan, Police Oil Cooler, 3.31 gears and a 5 speed.
post #7 of 10 Old 04-26-2005, 07:07 PM
bjsstang03's Avatar
brandon
GOD everytime im always in my brothers name! GOD anyway ya thats my post up top. LOL
post #8 of 10 Old 11-10-2005, 12:00 PM
Scones's Avatar
If you are an 87, you do have FORGED pistons. No worries. I'd find another working IHI turbo of another 87/88 Turbocoupe. They're a little smaller than a T3 so they will spool up a lot faster and are already set to run 9psi. You'll need to get a GOOD fuel pump, MAF conversion, 70mm bullet MAF set for 42 pound injectors (to be safe), as BIG an intercooler as you can find.you can bolt on everything you have then where you want it, then trailor it to a performance shop that will mandrel bend the pipes from the turbos to intercoolers then the pipe from the intercooler to the throttle body. Pic a shop that can burn you a chip from readings on their dyno for 94 octane (if your IC isn't big enough you'll also need to get manual boost adjuster...prolly should anyway). And a low boost blow-off valve would be a good purchase too.
Good luck and have fun
1986 5.0TT Tribute Car
2010 Ranger 4.0
1989 Kawasaki Ninja ZX6
Scones is offline
post #9 of 10 Old 11-10-2005, 12:03 PM
Erich's Avatar
I am running those IHIs. They work well.
Erich
Erich is offline
post #10 of 10 Old 11-10-2005, 07:20 PM
i posted a few car's you can look for at this link: https://www.corral.net/forums/showthread.php?t=717244
any of these would be a great way to enjoy your turbo'd stang.
wyominghotwheels is offline
