How to tell turbo size? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 04-07-2005, 10:54 PM Thread Starter
I just want to verify that a turbo is in fact a 57mm turbo. Is there any way to do this?
3Blk98Cobra is offline
post #2 of 7 Old 04-08-2005, 11:13 PM
Pull off the compressor cover and measure the smaller diameter of the compressor wheel with a caliper.
94 Lightning
Kenne-Bell Supercharged
78 Trans Am
400 w/nitrous
gasguzzler is offline
post #3 of 7 Old 04-09-2005, 11:40 PM Thread Starter
Thanks.
post #4 of 7 Old 04-10-2005, 07:09 PM
P.MUSSIN's Avatar
Make sure you measure the inducer (small part)not the exducer(big part)
Jeremy
P.MUSSIN is offline
post #5 of 7 Old 05-23-2005, 09:14 PM
where can i find carbed turbo mutang videos
convo2000 is offline
post #6 of 7 Old 05-23-2005, 10:46 PM
Where can I find a more random post? Nowhere, more than likely.
Black 1991 Notchback
Grabber Blue 2012 GT - HID's, Brembos, Nav
Red Metallic 2011 F350 Lariat CCSB
1000HP is offline
post #7 of 7 Old 05-25-2005, 11:21 AM
xr8240's Avatar
Check other links there...
http://www.turbomustangs.com/forums/...?s=&forumid=13
xr8240 is offline
