mm &ff high compression turbo/blower applications????????? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 04-05-2005, 09:07 PM Thread Starter
Red face mm &ff high compression turbo/blower applications?????????
I have a 357 that has 11.7 to 1 compression where is the expert that can tell me if i can put some boost to it.
I has forged rods and a 69 steel crank and it is a 69 block
what do you think?
orangeconv is offline
post #2 of 11 Old 04-06-2005, 11:55 AM
If you run it on alcohol...
Turbo5oh is offline
post #3 of 11 Old 04-06-2005, 07:21 PM Thread Starter
what about just race fuel or just low boost
post #4 of 11 Old 04-06-2005, 08:15 PM
Jesus christ, if they can run 25 pounds of boost on C16 on a 12.3:1 mod motor you can run a good amount of boost on an 11.7:1 357. I'd run C16 only and something intercooled, but you'll be fine.
highschoolphenom is offline
post #5 of 11 Old 04-08-2005, 03:40 AM
you can run low boost..............not an ideal compression ratio though...........
hotwheels of turborides
wyominghotwheels is offline
post #6 of 11 Old 04-08-2005, 08:25 AM
Well 14.7 pounds of boost doubles compression, so 8.5:1 at 10 pounds yeilds about 14:1 final. 11.7 at 3 pounds is about 14:1 final. 11.7 at 6 pounds is 16.5:1, about the same as 8.5:1 at 13 pounds of boost.
I see a lot of people running 10 pounds on 8.5:1 on pump gas, so it can be done, very low boost unless like turbo50h said you run alcohol.
1987stang is offline
post #7 of 11 Old 04-09-2005, 05:39 PM Thread Starter
well that is what I like to hear.
thanks when I get it ready I will get back with you
post #8 of 11 Old 04-09-2005, 05:59 PM
a mod motor is an absolutely terrible comparison for boost/timing/compression limits in regards to a windsor motor.
92fastlx is offline
post #9 of 11 Old 04-10-2005, 01:20 AM
It's close enough. If they can run that much boost on C16 there is NO reason why he can't run 10-15 pounds of boost on an aluminum headed windsor with C16.
post #10 of 11 Old 04-10-2005, 08:45 AM
Of coarse he can boost it! What 1987stang said was true, however alcohols is not needed. Heavy intercooling is a must along with high high octane fuel and of coarse back off some timing and set your tune correctly. However, if this is not a "race car" I would'nt recomend high boost apps. Have fun! Higher compression motors will always out-power low comp ones at equal boost pressures. Low comp can just avoid detonation better in high boost apps! Just remember as with any setup, the tune is the key to longer life!
Zmokedawg is offline
post #11 of 11 Old 04-19-2005, 08:21 PM Thread Starter
well it is about time some one has told me some type of information.
yes it will be a full race motor when the turbo is on and yes it will be intercooled.
thanks for some direction, I really had no idea that you could run a supercharger or a turbo on a high compression motor
