Switching to a carb set up... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 04-04-2005, 12:51 PM Thread Starter
Question Switching to a carb set up...
Question: Can I use my fuel injection pump (255 lph) with a carb pressure regulator? This will be a blow through set up, and I need a pump that can provide high fuel pressure and a pressure regulator that is boost sensitive. Problem is all the pumps I see are pre set at 8 -13 or so psi, however when I add boos the pump must be able to provide more pressure (8 psi base + 10 psi boost = 18 psi of fuel) Any ideas? What are u guys running for carb set ups (fuel).
Turbo5oh is offline
post #2 of 3 Old 04-09-2005, 05:34 PM
I think it would work as long as you run a BIG return line.
5.8 Bandit is offline
post #3 of 3 Old 04-16-2005, 05:20 PM
Fast90LXStang's Avatar
http://www.turbomustangs.com/forums/...?s=&forumid=13
'90 coupe sold
For what shall it profit a man, if he shall gain the whole world, and lose his own soul? -Mark 8:36
"Nietzsche is dead" -God
Fast90LXStang is offline
