Baseline results from LT1 single turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 05-15-2003, 08:32 PM Thread Starter
Since you guys have given me some good advice for my LT1 turbo project, I figured you may be interested in the results.
Here are some pics-
http://www.chitownsyty.com/gallery/v..._albumName=jim
Basics of the buildup are 357ci, AFR heads, 214/222 hyd roller, 9.2-1 compression, FAST bank to bank with WB o2, dual intank walbro 255's and 83lb injectors, Innovative GT80BB 1.32 A/R, Innovative indy gate, 6-speed, 3.42 gears.
Allthough I havn't got the boost controller installed yet, I strapped the car down on the dyno and was just using vacuum t's in the wastegate line to vary boost.
With 100 octane, it surged to 20 psi at 4,600, and then dropped off to around 16.
It made 645rwhp at 5,070 and 700rwtq at 4,650. Both HP and torque lines were on a steep incline until boost dropped.
Hopefully when I get the boost controller installed and see some steady boost it will lay down some REAL hp
96SS- Single turbo. 645rwhp 700rwtq and still tuning....
INTMD8 is offline
post #2 of 7 Old 05-16-2003, 12:25 AM
Man, that is too sweet. Makes you wonder what a tweaked LS1 with that set-up would do. Are you running the six-speed or auto? I see a new transmission and rear-end in your future!
swervin is offline
post #3 of 7 Old 05-16-2003, 12:31 AM
Right on.
Can you take the center section out the fascia to increase airflow over the intercooler. I am not sure if it'd look baad or not.
SvtJosh is offline
post #4 of 7 Old 05-17-2003, 10:11 AM
P.MUSSIN's Avatar
Congrats on the numbers especially since you built it your self!
Jeremy
Two turbos and a carb...
P.MUSSIN is offline
post #5 of 7 Old 05-17-2003, 12:19 PM
Simply awesome , and a clean install at that.
Is that black paint on the header some sort of high temperature coating?
Congrats!
Greg
mustanggreg is offline
post #6 of 7 Old 05-18-2003, 11:56 PM Thread Starter
Thanks guys
-I would rather not cut out the bumper for IC airflow. The bottom of the bumper curves up to the top of the IC core, so airflow should be sufficient. I'll get a pic from underneath for you.
The trans is a rebuilt 6-speed with a McLeod twin disc clutch. It also has a 12-bolt with 3.42's.
The headers are ceramic coated by Lo-Ko. So far it seems to be holding up nicely.
BTW, I just got back from WFC-6. I'm amazed by the numbers those turbo/blower cars are putting down!
INTMD8 is offline
post #7 of 7 Old 05-19-2003, 10:45 AM
simply amazing numbers. awesome car and application for some F/I.
great job.
let us know when you get the timeslips.
dark_rex is offline
