? about using a Blowoff valve with a Blower?Im using one on my S-Trim..???? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 04-28-2003, 09:46 PM Thread Starter
S-Trimmed302's Avatar
Trader Feedback: (124)
The Purple BLowoff valve is the one I have....I know I have a supercharger guys but I wanted to ask you Turbo guys about this Blowoff valve that Im using with my S-Trim..
Hey guys, I am running a Vortech S-Trim with a 2.95" pulley,4" Anderson powerpipe, Aluminum Vortech Discharge and a Greddy Blowoff valve vented Back to my powerpipe...My question is, I am running this valve like a BYPASS valve(I THINK) and have my vacuum line running to the Large vacuum port on the valve..I can hear the valve opening when I let off the gas but What exactly is that threadedrod on the end of the valve for??I think it compresses a spring to make the valve harder to open but Im not really sure..Should I run this stud all the way out while using it as a Bypass valve???ALso, what is that really small vacuum port for on thatvalve???I just have it capped off on mine now but Im not sure what it does....Reason I am asking this is I am only seeing 9-10# of boost with my 2.95" pulley and S-Trim and Im wondering if the Valve has something to do with it.This valve came with the whole Blower kit when I bought it used so Im using it.....Please help shed some light on this DIM subject if you can...Thanks so much Guys!!!
Jeff
S-Trimmed302 is offline
post #2 of 2 Old 04-30-2003, 07:52 AM Thread Starter
Anyone???? TTT
My 92 Coupe- Under construction - Dart 347, TFS 205 11R heads,Custom Cam by Brian Friedentag "freezy74",TFS Box R Intake, 75mm Accufab TB, Hooker Supercomp 1 3/4" Full Lengths,Vortech Pass side YSI,8" Crank,2.85 blower pulley,Treadstone 1245-28 Intercooler,Snow Stage 2 Meth kit
