Twin turbo stang needs a good clutch - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 04-25-2003, 01:29 AM Thread Starter
Hello everyone,
I just finished my tt setup. However my clutch, although good before, is now slipping unconctrollably at 2500 rpm and 5 psi of boost. Could someone recommend a truly streetable (daily driven) clutch.
chempowr is offline
post #2 of 16 Old 04-25-2003, 10:03 AM
Corral Charter Member
LXguy's Avatar
Trader Feedback: (92)
I would give Spec Clutches a call. They really know their stuff and make a good product. Tell them what you are after (that its a street car, for example) and they will get you what you need.
www.speclutches.com
Steve
2003 NMRA "Evil Twin" Pure Street championship car
(Driver: Darin Hendricks Crew Chief: Me
82 Ford Fairmont…NMRA FS 6777 (sealed CS Coyote engine)
www.coyotestock.com
LXguy is offline
post #3 of 16 Old 04-25-2003, 04:44 PM
Spec stage II. Stage 3 is too touchy, either on or off.
Chris
99 Procharged Cobra sold
95 Cobra single turbo. [email protected] stock block.
lightweight is offline
post #4 of 16 Old 04-25-2003, 05:49 PM
I use a SPEC stage 3 clutch..You cant really "slip" the clutch..But I use mine on my daily driver and have no issues with it..Just learn to drive around it. Ive never had any issues with mine slipping.
GT40X is offline
post #5 of 16 Old 04-26-2003, 05:26 AM
GT40X, you dont have any problems with it being really touchy? Thats what all i've heard about the stage III is being a PITA to drive on the street.
Chris
post #6 of 16 Old 04-26-2003, 05:54 AM
WhooshStang's Avatar
it's not bad once you get used to it, lightweight
WhooshStang is offline
post #7 of 16 Old 04-26-2003, 10:39 AM
BradleyRJ's Avatar
Trader Feedback: (25)
McCleod Street. Dual disc with a floater. Allows for slipping a little and holds like a mofo... Not sure about it fitting in a stock bell though. We've used these clutches in 800+ Hp Big blocks for a while with no problems.
They say what goes up must come down but I ain't reached my cruising altitude.
Take a look at what I did but can you imagine what I'm about to do.
BradleyRJ is offline
post #8 of 16 Old 04-26-2003, 01:41 PM
My king cobra clutch is toast, I'm going to try a king cobra pressure plate with a centerforce disc. I'm told this is a pretty good setup to 500 hp.
I have the disc already and a slightly used KC pressure plate so I may as well try it.
I do have plans to upgrade to a spec III when the funds allow.
05 GT
85 ASC McLaren Capri
79 Pace Car
19COBRA93 is offline
post #9 of 16 Old 04-27-2003, 01:04 PM
I have the spec stage III with the carbon pucks..Its streetable, just takes some getting used to, especially with an aluminum flywheel. I would suggest it if you need a clutch that will hold 700ft-lbs of TQ. Can be touchey with a big cam and alumiunm flywheel though...just like anything you get used to it.
Shaun
393"/twin T70/full accessory/billet ITB intake/stock hood/alum. 3.5" exhaust
Shaunthony's: you're gonna want to wear a cup
CobraSC is offline
post #10 of 16 Old 04-28-2003, 08:49 PM
Trader Feedback: (523)
guys email me at [email protected] for prices on Spec clutches and flywheels
jdsperformance is offline
post #11 of 16 Old 04-29-2003, 02:02 AM
Do you loose boost when the clutch slips. Mine is slipping I think. I loose boost in first and second it's getting worse. I noticed there oil on the inside of the scattershield. I wonder if that's why it's slipping. It is an iron disc can I clean it and reusee it?
1986 stang with TF TW heads and a Street intake, 36 pound injectors and pro-m calibrated MAF, 89 computer, Borla exhaust, Stock TB and CAM, roller rockers 1.6 ratio, stock shortblock with studded mains, and a T-5, twin T-3 .60/.63 turbo's ITS heafers and downpipes, Huge 24X16X4 intercooler, Autometer gauges idles like a kitten with stock computer!!!!
ng8264723 is offline
post #12 of 16 Old 04-29-2003, 11:54 AM
just sent out for spec II clutch... that spec III sounds like more than I need... the spec II is supposed to be good up to like 520 hp, that sounds good enough for my street applications for sure. I think if I go over that I will be shopping for a new trans and rear anyway.
wesleythomas77 is offline
post #13 of 16 Old 05-08-2003, 05:18 PM
Just got the car back from the shop that installed my clutch... cost 250, but it saved me the headache... and that included shaving down the flywheel, which I don't even have the tools to do...soooo... I am happy with it, it is different, more springy, but I am pretty used to it already... I will not be over 520 hp for a long time...
post #14 of 16 Old 05-12-2003, 05:57 PM
a couple days later, I would like to comment that it is totally broken in and it feels like my old clutch...
post #15 of 16 Old 05-12-2003, 09:48 PM
How hard is the pedal on the SPEC stage II compared to a stock clutch? I have a ford racing clutch and the car isn't as fun to drive with the pedal being as hard as it is.
bmore86 is offline
post #16 of 16 Old 05-13-2003, 03:45 AM
it is almost the same feel as the original clutch... however, I have not put the 500 hp on it yet
