Compression on a PI head swap car too much for turbo? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 04-10-2003, 10:23 AM Thread Starter
Question Compression on a PI head swap car too much for turbo?
I have a daily driven '96 GT and I am currently having a set of PI heads ported. My compression will most likely be ~10.5:1 because of my flat top pistons and the PI heads.
I want to know if this compression will be too high for a reliable turbo set up (with a low streetable level of boost, maybe ~8 lbs)?
Would a good tune take care of it?
I really don't want to change my pistons. So if it's not possible otherwise then I'll have to scrap the idea of turbo for now and just wait for a 2005 Mustang
scottinhawaii is offline
post #2 of 4 Old 04-11-2003, 08:08 AM Thread Starter
bump
post #3 of 4 Old 04-20-2003, 12:28 AM
ponyxpres's Avatar
Go to Turbomustangs.com, someone there might be able to answer your question. I would think it would depend on your tune.
ponyxpres is offline
post #4 of 4 Old 04-20-2003, 10:36 AM
xr8240's Avatar
Yes you can tune around it or even lower boost alittle !!
xr8240 is offline
