T64, 331, wastegate questions? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 04-07-2003, 12:50 PM Thread Starter
Looking into building my own single setup. Goals on stock block are 530 fwhp or around 450 rwhp? I want to keep the boost below 10 psi because of the 9.5 to 1 compression? Do you guys think I will be able to get away with a 35 mm Tial gate or do I need to step it up?
Thanks,
Anthony
90 Gt 331 FTI combo, AFR 165cc and eec tuner.
Coming soon - a quality paint job
In the distance - me wants a turbo
socks623 is offline
post #2 of 7 Old 04-08-2003, 11:46 AM
I think the lowest it'll handle is 10 psi. Any lower than that I suggest maybe a 40mm.
"Dream as if you’ll live forever. Live as if you’ll die today."
-James Dean
boostedfoxbody is offline
post #3 of 7 Old 04-09-2003, 10:17 AM
with the 10 psi that you want, the tial 35mm is fine.
kdirty130 is offline
post #4 of 7 Old 04-10-2003, 02:21 AM
i have a 35 mm tial gate on my car and i can drop boost to 7.5 psi with no spikeing above 9
my car is a 347 with a t-76 turbo on it.
twinturbosaleen is offline
post #5 of 7 Old 04-10-2003, 02:09 PM Thread Starter
Thanks, twinturbosaleen thats what I was looking for, if it will work with a T-76 then I would assume that it will work with a t-64. If worst comes to worst i'll throw another 35 mm on there, then I'll be set for sure.
Anthony
socks623 is offline
post #6 of 7 Old 04-16-2003, 01:17 AM
Quick tip, if you get a 35mm Tial w/ a .65 spring (9psi) and want it lower simply hook the boost reference to the lower port on the gate and leave the top one to atmosphere. This should give you between 6-7psi.
turbostangman is offline
post #7 of 7 Old 04-17-2003, 10:56 AM
I'm a little confused on the line connections for the wastegate. Is the top one for a manual boost controller? If so, is the lower port connected to the turbo's boost reference, and the top port connected directly to the boost controller?
I'm using a TurboXs Hi-Performance boost controller connected as mentioned, but I'm not sure if it's connected correctly. I have it set it to the lowest setting possible, but boost will go as high as 15-16psi The boost controller is brand new, so I'm wondering if the way it's connected is the problem.
-James Dean
