daily driven turbo 351 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 04-01-2003, 08:08 PM Thread Starter
BSapphire95GT's Avatar
I want to swap in a 351 in my sn95 mustangs, and basiccaly i want it to run mid to high 11's with room to go faster. What kind of turbo, boost, and heads, and intake, and compression ratio would i need to run? I want it to be streetable...any ideas?
1995 vibrant red GT
BSapphire95GT is offline
post #2 of 2 Old 04-02-2003, 10:36 AM
most people are running in the hig 11's with stock motors....you can go to www.turbomustangs.com and look at the owners list page....it gives details of others setups and that should help you greatly...
however. with your set-up, you should be able to run 10psi with a T64 or similiar and mid 11's with no problem. ... assuming it is intercooled and you get a good tune in the car so you dont destroy the motor.... even the T64 will split the block or break other stuff....
hope this helps
91 coupe: Dart 408,EFI, AFR 205's, FTI Cam,160lb injectors, 91mm turbo, A/W intercooler, Glide, 3.27's 921 RWHP @ 14psi and 93 octane & 1053 on 21 psi..
http://www.youtube.com/watch?v=6zHnpdtharc
forced5 is offline
