Combo Change: E.T. Predictions - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 03-28-2003, 11:02 AM Thread Starter
I posed this same question on TurboMustangs.Com but I thought I'd try here as well:
I've got a 93 coupe with a home built single turbo. The current combo:
  • T5 with a not too happy clutch
  • 3.27 gears with 31-spline stuff.
  • upper/lower control arms.
  • Lakewood 70/30s and 50/50s.
  • All of D&Ds stuff up front.
  • 26x10.5 E.T. Streets.
  • Car weighs just a tick under 3000lbs without me in it.
  • Car makes 460rwhp/540rwtq.
New combo is a built AOD (TSI out of Illinois - Rick Anderson recommended) and a 2800, 9.5" PI stall converter.
Here is a video of my best 1/8th run to date - 7.70 @ 95.4mph.. I was running 9psi on that run and I usually run 12 or so. The track/clutch wouldn't hold more than 9psi on this day. I had a 1.92 60' on that run and I was babying the T5 and the clutch pretty good. What should I expect with the AOD setup?
302_plus_a_few is offline
