Anyone out there have a jytt twin turbo 95? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 03-25-2003, 07:01 PM Thread Starter
Hello, I'm going to start building a jytt kit for my 95 and I need some ideas. If you have any tips or pictures that would be great. Thanks
blue hummvee is offline
post #2 of 6 Old 03-26-2003, 01:34 PM
I've been looking at the idea for quite awhile. I bought a PTE PT-70 for my car. I started placing the turbo in different areas under the hood to find the best fit. What I decided to do was to swap to Fox body engine brackets and accessories. So far I've spent around $75 on all the brackets, 2 tensioners, bolts, timing cover, etc. Changing to th earlier brackets is by far the easiest way to make your own setup. In your case that would make flipping the stock shorties VERY easy which would not be at all possible with the stock SN-95 brackets. The header on the passenger side can be flipped but the drivers side cannot because of the AC lines, etc. I thought about coping the SN-95 Cartech/TTI setup but it seems like the log style headers are not the best way to go. So I plan on running two shorty headers mounted backwards pointing down and copy the TTI or Cartech Fox body setup. I plan on starting in about a month. There will be lots of pics . You can search the net but I didn't come up with anything that helped me other than looking at all the major kits out there and made my decision from there.
Good luck!
Matt
Matt W is offline
post #3 of 6 Old 03-26-2003, 05:34 PM Thread Starter
Hey Matt, Thanks for the info. I was looking at that kit too...Lots of money! So I'm going the cheap way...building my own. When you start feel free to send some pictures. [email protected]
Talk to you later.
Dan
post #4 of 6 Old 03-26-2003, 06:56 PM
P.MUSSIN's Avatar
Alex in Houston has done a JYTT and JYsingle, do a search and PM him he has a web site, check it out!
Jeremy
Two turbos and a carb...
P.MUSSIN is offline
post #5 of 6 Old 03-27-2003, 05:57 AM Thread Starter
Thank You !
post #6 of 6 Old 03-28-2003, 07:47 AM
paluka21's Avatar
Sorry to hijack the thread,, hey Matt W, get my email?
Dan
paluka21 is offline
