new in-tank pump? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 03-22-2003, 02:00 PM Thread Starter
Question new in-tank pump?
My stock gas pump is about to die and since I'll go turbo sometime in the future I wonder if it's worth replacing it with something else at this point... Any suggestions are highly appreciated!
Thanks!
'95 Rio Red GT. AODE to T-56 (w/Pro 5.0), Double-Kevlar clutch, FRPP 3.73 gears, Griggs Aluminum driveshaft, Griggs "almost full" suspension (minus rear coilovers), Tokiko Illumina 5-way shocks & struts, MM Camber/Caster plates, Baer 13" front brake kit, Bassani cat-back exahust, Fluydine alum. radiator, Stewart Components performance water pump, 180 deg. thermostat, Moroso Battery-in-trunk kit, Walbro GSS340 in-tank fuel pump. Oh.. and a PTK Single Turbo Kit...
MxStang is offline
post #2 of 2 Old 03-22-2003, 05:01 PM
P.MUSSIN's Avatar
If you are going to go to any kind of power adder get the Walbro Gss340 (255).
Jeremy
Two turbos and a carb...
P.MUSSIN is offline
