Dual 5" exhaust? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 03-12-2003, 11:43 AM Thread Starter
BOSSCAT's Avatar
Dual 5" exhaust?
I know someone thats want to put this on his car, I told it was too big. He said its perfect for a turboed car.
He reasoning is turbos do not like back pressure, so the bigger the exhaust the better.
Is he right?
Skyline R32 GTRBlown 05
R32 GTR w/351w, 8.9:1, PTK T76, 40 BC & 45 WG, 40 BV, AFR 205, F303, 1.7rr, RLs, 4" exhaust, IC, 8 point cage, C2s , C4 3200 stall, CSU 750 & bonnet, Vic Jr, 3.63, Corbeaus Custom body, Bomex & Tommy Kaira body kit
'70 Boss 302 Cougar Eliminator
BOSSCAT is offline
post #2 of 11 Old 03-12-2003, 07:57 PM
First5.0's Avatar
well you have to remember that if you go with dual exhaust, you are actually splitting ONE exhuast pipe (if its a single turbo...) into two exhaust pipes. generally when you do something like this you would make the two pipes a smaller diameter than the one which is being branched off of. i dont know for sure, but i would say dual 5" is 2.5" too much =)
Coupe, Legacy
First5.0 is offline
post #3 of 11 Old 03-13-2003, 02:28 AM Thread Starter
BOSSCAT's Avatar
He is talking about a TT set up. I agree too big as well. My problem is, I do not know how to explain why?
BOSSCAT is offline
post #4 of 11 Old 03-13-2003, 06:47 AM
xr8240's Avatar
Twin 3" for better clearance. imo..
xr8240 is offline
post #5 of 11 Old 03-13-2003, 07:52 AM
I would LOVE to see how he is going to fit 5" downpipes past the strut tower/block/header area. Nick
NiceGuyNick is offline
post #6 of 11 Old 03-13-2003, 01:14 PM Thread Starter
BOSSCAT's Avatar
Its actually going on a GTR, but an engine is an engine.
I have received valuable information from this board that crosses over into other types of cars.
That is why I queried on here. Thanks for your input.
BOSSCAT is offline
post #7 of 11 Old 03-13-2003, 06:23 PM
5" would be extremely too big, yes turbos do not want back pressure but then people think well lets just go huge and that way there will be no back pressure at all. I will look it back up but if you get the book "Maximum Boost" by Corky bell, he explains it to a tee about how wide of exhaust to go. For one tailpipes are terrible on tuboed cars. I am going single with just a 3" downpipe going back to a Race Magnum all 3" then dump it right before the axle. But yes you can go to big and remember no chamber muffler
Blow_Me93 is offline
post #8 of 11 Old 03-15-2003, 04:00 PM
Maybe for around 2000hp, but not for anything less. Dual 3" will be plenty up over 1000hp.
99 black cobra built bottom end, ported NAVI heads, cams, etc. n/a w/n20
93 white coupe- 306ci, 14psi s-trim, tko600
'06 black Subaru STI- spec clutch, blizzak snow tires, 475hp on 91 octane.
N2O88 is offline
post #9 of 11 Old 03-21-2003, 12:22 PM
blackgtstang's Avatar
i dont run any mufflers at all. Just dump pipes off the h-pipe. I am going to get a catback eventually but I have had no problems so far with the setup like that.
00 GT-5sp-Some bolt ons
x2c Coilover kit front and rear
blackgtstang is offline
post #10 of 11 Old 03-25-2003, 01:00 AM
That'd be the perfect size. If it were a Peterbuilt.
SvtJosh is offline
post #11 of 11 Old 04-12-2003, 11:44 AM
You won't lose power from dual 5's....but you reach a point of no return. 3 inch dual or 4 inch single, plenty eitheir way.
ItsStockOfficer is offline
