twin turbo setup on stock motor - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 03-03-2003, 09:09 PM Thread Starter
86drop's Avatar
Question twin turbo setup on stock motor
few questions for ya:
1. is there anything i need to make sure i do when rebuilding the motor to prepare it for being turboed?
2. since i wanna go twin im assuming 2 T3 turbos is the best way to go....am i correct in that assumption?
3. what kind of fuel system changes would i need to make to accompany this? what size injectors...fuel pump...etc.
4. also, any other suggestions on things i might want to do are appreciated
thanks!
ryan
86drop is offline
post #2 of 8 Old 03-05-2003, 09:07 PM
if you are just going to use the stock motor and heads, get some copper head gaskets and new head bolts....i like twins myself and you should be okay on a stock motor; would guess horsepower would be in the 340's on stock...i would suggest 36 or 42# injectors and a 255lph fuel pump, fuel pressure regulator and a fuel pressure gauge........hope this helps, your friend, wyominghotwheels
wyominghotwheels is offline
post #3 of 8 Old 03-06-2003, 10:21 AM
Just dont rebulid the motor And run about 15psi just my 2 cents
ONEMEAN460 is offline
post #4 of 8 Old 03-06-2003, 01:53 PM
P.MUSSIN's Avatar
1.If you are rebuilding the motor I would just put ARP rod and head bolts in, and maybe some main studs. For a daily driver I like to run 9:1 (stock comperssion) pistons and a good set of rings.
2. I run the T3's(.60/.63) they work great! You could also find some Grand National turbos for extra power, but the T3's are good to like 650hp @ the motor.
3. I run a 255 in tank, 255 in-line, Kirban ADJ fuel press reg, 42lb Lucas injectors, NO FMU.
4. Do alot of research on this subject, www.toohighpsi.com , www.turbomustangs.com, go there lots of good info, check out the links. GOOD LUCK
Jeremy
Two turbos and a carb...
P.MUSSIN is offline
post #5 of 8 Old 03-08-2003, 12:03 PM
You'll make way over 340hp. I ran 36lbers on my car with a gss340 and kirban thats it. You can use a variety of turbos, more than enough to split the block. Definetely use the head studs and probably some 1011-2's, i personally wouldn't use a copper head gasket but thats me, too many horror stories. Think of the the head gasket as the fuse, would you rather replace a head gasket or change the pistons or block or something else, etc, etc.
"The junkyard dog"
90 cpe w/ twin turbos
10.9 @125 bone stock motor w/13psi of intercooled, untuned
boost
ntrcptr90 is offline
post #6 of 8 Old 03-10-2003, 08:14 AM
ntrcptr90
are you running stock heads and intake also, just out of curiosity
Blow_Me93 is offline
post #7 of 8 Old 03-10-2003, 04:37 PM Thread Starter
86drop's Avatar
yeah, its a stock '91 5.0 that supposedly had some port work done to the heads and intake.
86drop is offline
post #8 of 8 Old 03-10-2003, 08:59 PM
Originally posted by Blow_Me93
ntrcptr90
Yes i was(i.e no port work), the motor is now getting torn down and getting h/c/i and nitrous and going in my girlfriends coupe. The motor was bonestock except for a 70mm accufab tb/egr and exhaust. I had msd 6al as well.
"The junkyard dog"
boost
