AFM cams, whos running one- Need opinoins? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 03-03-2003, 12:07 AM Thread Starter
Well ive been looking at cams lately since im in the process of a 331 stroker build up (331, Edel RPM, AFR185's, S-trim 14-15lbs)
Now i am looking at these two cams, The B31 and the B41..
The B31 is designed for 8-15lbs of boost and the B41 is for 14-20lbs. Both are obviously blower grinds. I recently read an article in MM&FF where a guy made 544RWHP and similer torque in an aode, with a Novi blower, 331 stroker, trickflow heads and cam(box stock) and the B41 cam.. Very impressive, and im hoping to make similar numbers when im done with my motor. Im just stuck on a cam selection, and need alittle guidence.
Thanks, Mike
poostang is offline
