Different size turbos ok?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 03-01-2003, 09:40 PM Thread Starter
Well, I might be trading some efi parts for 2 t3's but Im not sure if its a good idea or not cause they are different sizes... heres what the guy has to say about them:
I have two T3's .60/.63 that I may part with, but if I do sell them I am only selling them as a pair. I will not split them. . Right now I am waiting on two 1/2 inch weld flanges for the turbine housings that I ordered about 2 weeks ago. I have purchased a supercharger but I am not real sure I really want to let go of the turbo's.
I bought the turbos about 4 months ago to start a twin project. They have not been rebuilt. They only have slight axial play in the shafts, and there is no evidence of oil residue in the turbine housings, which would indicate a bad seal and the cause of the puffs of oil smoke on acceleration. I removed the compressor housing and turbine housing from one of the turbos just to inspect both of the wheels. The turbine housing on that turbo is going to be replaced with a reman unit which is 50 bucks. I can get that from Majestic turbo here in Dallas. Bot of them appear to be in good shape. Yesterday UPS dropped of the 1/2 Weld flanges that I order 3 weeks ago, so if I sell the trubos the new flanges will be included. These are very nice flanges, and won't warp like the cheap 3/8 flanges, to aid in building your own manifold setup.
Since I will replace the one exhuast housing with the reman unit that will put me at 500.00 in the turbos. I have no issues with installing them as they are without a rebuild, and am still not 100 percent sure I want to part with them, but then again, I need other items for my Procharger setup.
8mpg is offline
post #2 of 9 Old 03-01-2003, 10:44 PM
...unless I missed something, I only see one type of T3 there - a .60/.63. I read it as they are both .60/.63's so I'm not sure what the problem is
92fastlx is offline
post #3 of 9 Old 03-01-2003, 10:47 PM Thread Starter
im stupid...i know nothing about turbos, this will be my first turbo motor....
thanks
8mpg is offline
post #4 of 9 Old 03-01-2003, 11:13 PM
well the .60/.63 is a good t3 to use for a 5.0 twin setup...so, goodluck with whatever you decide to do
92fastlx is offline
post #5 of 9 Old 03-01-2003, 11:14 PM Thread Starter
I was planning on getting a stout Rblock or A4 block and running some major boost. What kind of power do you think I can squeeze out of the turbos?
8mpg is offline
post #6 of 9 Old 03-02-2003, 02:48 AM
I don't think those turbos will necessitate a A4 or R block. I'd guess you could stretch 600HP at most.
Be careful about what your getting there. Find out why that turbo needs a new turbine housing. The guy kinda sounds like he knows what he's talking about. Also make sure you get the wastegate actuators. Remote wastegates can set you back about $250 each.
Erik88GT is offline
post #7 of 9 Old 03-03-2003, 12:31 AM
ok now i have a question cause i have got two different sized turbos i want to use one is .48 a/r and one is .63 a/r would it be ok to use these on a twin setup?
ItCouldHappen is offline
post #8 of 9 Old 03-04-2003, 01:14 AM
Probably not, but you could try it and see. I'd be interested to see what happens.
Erik88GT is offline
post #9 of 9 Old 03-06-2003, 02:20 PM
I think you would want slightly larger turbos on your low compression motor, but what kind of hp goals did you have in mind?
lit_mike_2001 is offline
