Need help with Turbocharer A/R - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 02-26-2003, 08:13 PM Thread Starter
Does anyone know if the turbo compressor housing itself has an airflow limit? I know the wheel controls much of the airflow, and that's what all the maps show, but I'm curious if a t04b .60 a/r housing has a limit of airflow it can handle. I'm trying to figure out if some of these people I talk to are full of crap about what there turbo is capable of.
Zeet's5.0 is offline
post #2 of 5 Old 02-26-2003, 08:23 PM
the highest output t04b housing setup i am aware of is w/ a 60-1 wheel. that flows about 55lbs a minute. i know that when you change it to a t04e housing w/ a 60-1 wheel you can pick up 5-10% more airflow.
clement is offline
post #3 of 5 Old 02-26-2003, 08:40 PM Thread Starter
Thanks for your reply Clement. Do you know if that is a .60 a/r housing they use. I know I have to use a .70 for an H3 trim compressor wheel. I'm just trying to figure out the flow limit of the .60 housing itself.
post #4 of 5 Old 02-26-2003, 08:43 PM
i think mine was a .60 a/r intake housing. it was a 60-1 wheel w/ a t04b housing (60-1hifi) w/ a p-trim turbine and a .96 exahust a/r.
clement is offline
post #5 of 5 Old 03-01-2003, 01:10 PM
I always figured flow only had to do with the mm inlet size... I never really thought about a/r on compressor side. Good question...
05 GT
85 ASC McLaren Capri
79 Pace Car
19COBRA93 is offline
