turbo questions, need professional help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 02-23-2003, 07:36 PM Thread Starter
i have 2 problems, 1st is that i have a 2003 cobra that isnt fast enough, 2nd is that i have more money than sense and i dont have much of either.
im gonna put the system that i have designed in my head for all to help with so i can hopefully take the path of least problems.
t72 turbo, single
in car boost adjuster
remove blower and IC and replace with avaitor intake
swap timing chain cover to 2001 setup so i can put the alternator back off of the 8 rib pulley setup, and remove the 8 rib stuff for more space.
remove all exaust to run single side exit setup
no cutting frame
55lb high impendence injectors with stock 03 pumps, fuel system kept returnless.
stock computer, no fast or gen7
front mount IC
800 rwhp??
i really dont want to drop 1400 bucks on a injector driver, 2500 on a dfi setup,
i already have a spec stage 3 clutch, the restof the driveline should hold it correct?
how much money do you think i will spend start to finish, tuned and rolling
matt lankford is offline
