Turbo from 81 280z - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 02-19-2003, 04:55 PM Thread Starter
Turbo from 81 280z
Is a turbo from a Nissan 280Z good for one of my turbos in a jytt kit I found ond on a car here in a local junk yard and on the exhaust part I can read .63 A/R and on the turbine side is says Nissan
ItCouldHappen is offline
post #2 of 3 Old 02-20-2003, 08:49 PM
Turbo 5.0 Mike's Avatar
Old.
It's old and inefficient. You're better off grabbing two turbos off of a Turbo Coupe or something newer. Those turbos were from back in the day when there wasn't much science put into the design of turbos and what the end use would be.
Take a look at the horsepower rating of the 6 cylinder, 2800cc turbo Nissan 280, and compare it to the smaller, 2-slug disadvantaged, 2300cc Turbo Coupe from 8 years later and you will see the horsepower output is probably greater on the Turbo Coupe.
MJB
Turbo 5.0 Mike is offline
post #3 of 3 Old 02-21-2003, 06:09 AM
xr8240's Avatar
I'm using twin T3's off single turbo VG 30 Nissan 300ZX. They are ball bearing etc..Latter model than the one you stated...
xr8240 is offline
