On3 install questions - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 04-08-2018, 04:30 PM Thread Starter
Right now my motor is out of my car and I installed the headers befor I am going to put it back in. I donít have o2 sensors right now but I ordered them being I could get them cheaper then my local store. My question is can you install them once the headers are on and motor is back in the engine bay or are things to tight? I donít want to have to take the headers off while itís in the car just to put them back on again when the sensors come
1992 black notchback... 347 boss block, afr 185 renegade, 80lb injectors, edelbrock rpm II, on3 7675, tko 500, 3.55 gears
Powerstroken is offline
post #2 of 11 Old 04-09-2018, 12:22 AM
You shouldn't have a problem the O2 sensors are easy to get to.
Before you drop it in, check your header clearance along the pass. frame rail, i had to do some grinding to the top lip.
I've installed the hotside twice now with the motor installed. I've found the higher hard top motor mounts allowed for a better overall fit over the lower convertible mounts on my particular car. My downpipe slid in much easier and the crossover pipe and charge pipe have more room.
1991 Mustang LX - 306, Ported Holley Systemax, 11R 190 heads, FTI cam, 70mm TB, On3 Turbo kit w/67mm BB .96a/r, PT 46mm WG, MSD6AL-2. Freddy Brown Built FMVB AOD w/brake, 3K stall. 3.27's
My96z is offline
post #3 of 11 Old 04-09-2018, 08:07 PM Thread Starter
Did you dimple any of the primary tubes by the bolts to the heads? Some seem a little tight and seem like they would suck to get off while the motor is in the car
post #4 of 11 Old 04-09-2018, 09:43 PM
No, I didn't dimple anything. I used a combination of studs and Mr gasket locking header bolts and Remflex header gaskets. The flange bolts are just one of those things that will take a bit of time to get them all tight.
My96z is offline
post #5 of 11 Old 04-16-2018, 09:12 AM
I used the on3 bolts just fine, taken the kit off/on probably 4 times now. you just have to install them all at the same time by turning each bolt a few turns at a time. Can't run any one bolt all the way in before the others are threaded in or else you'll have issues. I made a big writeup for the install of these kits somewhere. I'll try to find it.
5.0thunder is offline
post #6 of 11 Old 04-16-2018, 09:18 AM
My big post is in this thread, in case you need some help.
https://forums.corral.net/forums/turb...tructions.html
post #7 of 11 Old 04-17-2018, 11:41 AM Thread Starter
Well I have the majority of the kit installed the problem Iím having is how close the alternator is to the turbo. I want to keep my power steering so I donít want to put it on the driver side. Hopefully I can figure something out
post #8 of 11 Old 04-18-2018, 07:09 AM
I'm having the same issue. I also am installing a ON3 kit but I'm using a percision 70/75 turbo and percision 46mm waste gate. My alternator is very close to the turbo and I still haven't installed the belt. I'm worried that once the belt is on and if it requires some tension I wont be able to move the alternator out to add tension. Looking for a solution.
Miguel87LX is offline
post #9 of 11 Old 04-18-2018, 07:57 PM Thread Starter
Iím thinking get one slightly tight and just pry it on if worse comes to worse
post #10 of 11 Old 04-23-2018, 04:30 PM
pulled the alternator in as close to the water pump as possible, measured that length with a string, then went to the auto parts store and bought a belt that was very close in length. barely had to adjust the alternator to give it adequate tension. also make sure the turbo compressor housing is clocked downward so that it's as far from the alternator as possible.
post #11 of 11 Old 04-23-2018, 05:47 PM Thread Starter
Yeah Iím currently on the belt hunt hopefully have it wrapped up this week
S197 & On3 Kit Questions Opti S-197 Mustang (2005-2010) 9 03-31-2014 10:13 AM
Vortech v1 s-trim install questions and parts nick1990 GT & SOHC 9 08-05-2013 03:03 PM
Started an On3Performance install have some questions. mu$tank Turbochargers 28 03-12-2012 01:17 PM
Methanol injection install questions.... redsaleen1 5.0/5.8 Engine Tech 0 02-09-2012 01:46 AM
On3 Performance Turbo Kit Install ModularSpeed Turbochargers 176 02-07-2012 11:52 AM
