Which Fuel Pump???351 TWIN TURBO - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 02-14-2003, 05:49 PM Thread Starter
Trader Feedback: (22)
Question Which Fuel Pump???351 TWIN TURBO
I have BBK 255 in tank , would this be enough pump 15# boost , 42# injecters , Vortech Fuel Rails , if i need more pump please help with suggestions.............THANKS
351turbo is offline
post #2 of 11 Old 02-14-2003, 06:15 PM
Andrew's Avatar
I would go with a serious pump setup... i.e. aeromotive, weldon, etc.
431.8 CID Al motor by Steve Petty, TEA #7721 heads (386/312 cfm), TEA Super Victor, Custom solid roller, PTK 1 7/8" stainless, PT-106, ladderbar. Goals: 4.60's @ 160ish on 10.5W tires. Coming soon: PT-114.
Best so far: 4.83 @ 150.7
Andrew is offline
post #3 of 11 Old 02-17-2003, 03:09 AM
351turbo: do you have any pics of your setup and what turbos are you useing thanks
dave ross
1slow90stang is offline
post #4 of 11 Old 02-17-2003, 03:11 PM
15 pounds of boost through a 351, you might have to worry about the 42's being too small.
1000HP is offline
post #5 of 11 Old 02-17-2003, 09:45 PM
Ian
Ian's Avatar
Ian is offline
post #6 of 11 Old 02-18-2003, 09:33 PM
IMO you need to replace the entire fuel system from the tank to the injectors. I agree with other that 42#'ers are not enough. Fifteen pounds of turbo boost on a 351W is going to make ALLOT of hp. I bet with a good tune you'll make over 600 rwhp and 600+ rwtq. That kind of power will show you allot of weak links in the drive train/rear suspension. It should be a scary fast ride once you get it up and running.
'89 LX 5.0L, T-56; SVO Ceramic Shorties; Ultraflow Cat-Back; 1.7 SVO Rockers; Pro-M 75mm MAF; 42# injectors; 75mm Throttle Body/EGR; 3.55 FMS Gears; GT40-X heads (64cc/ported); #2031 Cam; 12 psi Kenne Bell 2200 w/ Flowzilla; SMC W/A Injection; J&S Timing Controller; TwEECer RT; DIY-WB
Michael Johnson is offline
post #7 of 11 Old 02-19-2003, 04:23 PM
If you would like to save money on a proven fuel system, then either of these would work for you. Mental Addiction Motorsports is running a GP on these systems currently.
Cartech Preston is offline
post #8 of 11 Old 02-21-2003, 04:46 PM
Preston: How much RWHP from a turbo car will that fuel system support?
1000HP is offline
post #9 of 11 Old 02-21-2003, 08:06 PM
A Stage 2 fuel system is capable of supporting 800HP from a forced induction car. You can easily upgrade the pump to an Eliminator or Pro Series pump to bring it over the 1000HP mark. The Stage 3 will support about 1000HP.
post #10 of 11 Old 02-21-2003, 08:46 PM
How loud is your stage 3 system? Is it livable for a car that's going to see a LOT of highway miles?
1000HP is offline
post #11 of 11 Old 03-02-2003, 02:39 AM
The Aeromotive pumps are NOT noise makers like the Weldons. Be careful in your choice if you go with a Weldon as a few of their pumps are not rated for continuous duty.
vinny5oh is offline
