Pics of the turbo installed - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 02-14-2003, 09:24 AM Thread Starter
There is still some finishing touched to be done - like a solution for the fuel lines, but it runs darned good.
Mike Smith
1990 LX Coupe 5.0 5 speed w/ 2000 Exploder GT-40 engine, P heads, mystery cam (F cam per previous owner) 3.73, and not much else. In the parts pile - UPR tubular K member, CC plates. Future plans - Megasquirt & On3 turbo system.
Catfish is offline
post #2 of 6 Old 02-14-2003, 09:57 AM
P.MUSSIN's Avatar
Looks pretty sweet Mike You got any pics of the Exhaust? Keep us posted...
Jeremy
Two turbos and a carb...
P.MUSSIN is offline
post #3 of 6 Old 02-17-2003, 12:22 PM
LAST302's Avatar
I noticed that you ran the fuel lines above the intake pipe and have them wrapped in something. Are you that worried about heat? Actually, as I look closer, it looks like you've got all kinds of wires pulled up out of the way!
Dave
331 with HCI
Pics
Original owner
LAST302 is offline
post #4 of 6 Old 02-17-2003, 12:29 PM
Is that a MSD ignition box under the hood? Underhood temps are about 300 F in the summer I venture......that MSD is going to be hurtin'.
The turbo setup is sweet, nothing like a real deal power adder kit to see once in awhile. Awesome.
CASturbo is offline
post #5 of 6 Old 02-17-2003, 01:08 PM
my msd has always been by the exhaust housing. never had a problem. drove it in the summer all the time.
clement is offline
post #6 of 6 Old 02-17-2003, 02:30 PM Thread Starter
Yeah, I am worried about the heat. The fuel lines should run under the intake tube, above the exhaust side of the turbo. It gets a might bit hot there. I decided to put them over the intake. I also put some asbestos wrap where they contact the intake tube. Ultimately, I will remake fuel lines and run them differently. The other stuff is vacumn related. I need to get all that sorted out so it looks better. This install just got done, so I wanted to run it a little and make sure the kinks were worked out.
At this time, I have the car back on the lift. The clutch (stock) started slipping immediately, so that is getting changed. I also have a leaking crossover pipe. I am remaking that part. I do not like the way the one with the kit was run. I may also end up making my own Y pipe, as the one that came with the kit needed some persuasion to fit correctly.
It's running good, but the details are a work in progress.
Mike Smith
Catfish is offline
