Anyone with a cartech system w/T-76 for street? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 02-11-2003, 08:58 AM Thread Starter
ybnorml's Avatar
I'm considering swithching from a blower to a turbo. I found a t-76 turbo kit and wondered if anyone has this kit on a semi street car? My car is only driven on weekends and at the strip. How streetable is this kit? Do you have to remove your power steering? How much hacking in the engine compartment or anywhere else do you have to do. Anyone that has this kit, or who has had experience with this turbo, I would greatly appreciate any info that you have. Thanks!!
2008 Shelby Convertible
92 GT Turbocharged 70mm
2014 F150 Ecoboost App Pack
ybnorml is offline
post #2 of 3 Old 02-11-2003, 03:37 PM
There's two type's of cartech single kits, the "Street sleeper" and the "outlaw, both can accomodate a T76. The street kit can retain all accesories (ps is relocated with special bracket) The outlaw can not retain A/C or PS or sway bar, the biggest noticable difference is where the cross over is, on the Street kit it's behind the engine, and the outlaw its in front of the engine
Good Luck
More info @ www.turbomustangs.com
Superskwrl is offline
post #3 of 3 Old 02-12-2003, 11:38 AM
fast4d's Avatar
I have a "sleeper" kit with a T-72. I see 2 issues with a T-76. Even a T-72 is huge and you'll have to cut a chunk out by the frame rail to fit the turbo. Does your turbo header have a 2 bolt flange for the wastegate? All the bigger wastegates use a different flange so a deltagate/tial 35 may not be enough if you run a lower amount of boost
Alan
'89 GT (331, Canfields, FAST EFI, T-70, Griggs GR-40) 550rwhp/640rwtq @ 15psi 91 octane
'98 M3 /4
fast4d is offline
