Aluminum heads?! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 02-11-2003, 01:49 AM Thread Starter
Aluminum heads?!
I am thinking about switching out the heads when i get my twin turbo setup rolling (heh gotta keeps saving money and then gonna try to do everything at once!), would Twisted Wedge aluminum heads be a good choice, or how about some AFR heads? what do you guys think?
Ethereal_Zer0 is offline
post #2 of 7 Old 02-11-2003, 05:34 AM
Ian
Ian's Avatar
Do a here for the best heads to use.
I would personally go with the AFR's as I feel they are the best heads out there today.
Ian
Ian is offline
post #3 of 7 Old 02-11-2003, 02:24 PM Thread Starter
well mostly i am was just wondering if aluminum ones would be ok or not, i'd heard from ppl that the turbos make too much heat and to bad things to the heads?
edit: heh sorry about my first post, just re-read it, it does sound like i wanted to know which heads would be best!
post #4 of 7 Old 02-11-2003, 09:43 PM
EvilTwistedTwins's Avatar
Do some TFS TW heads or Edelbrock Victor 5.0 heads.
"Nitrous is like hot girl with with STD's. You know you wanna hit it, but your afraid of the consequences."
EvilTwistedTwins is offline
post #5 of 7 Old 02-12-2003, 12:15 AM
it's hard to search when all the good tech got lost in a freak DB accident
Tyler, As for the aluminum heads you'll be fine, infact you'll be better off because they help get the heat out of the chamber better to help keep detonation at bay. TW's, AFR's, hell even GT-40X would be fine for what you're doing with the stock block and all.
WaterPog is offline
post #6 of 7 Old 02-12-2003, 01:39 AM
Moderator & USAF Active Duty
Dave88LX's Avatar
That was just General Tech. Windsor Tech is all still there
Dave88LX is offline
post #7 of 7 Old 02-12-2003, 04:09 AM Thread Starter
thx Eric heh i've been burning oil lately *cringe* so i was thinking maybe i could get some aluminum heads (if valves are the culprit) and that would solve the oil problem, and get me started onto my turbo mods! i still gotta check to see if its the valves or not, but i may just get alumiunum heads anyways if i can afford them, can always use more power!
Edit: damn my spelling! damn it all!
