Timming questions.......... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 02-06-2003, 11:18 AM Thread Starter
P.MUSSIN's Avatar
Question Timming questions..........
What would be the bennefit of locking you timming to a specific degree ???? So instead of running around with the timming set @ 10 then seeing 26 @ WOT, would just setting it @ 26 then pulling the spout out be more bennificial??? I think it would tend to cause a broblem with tip in detionation, but have never tried it. I have a chip that gives me 16 degrees @ WOT on side "A" and 23 degrees on side "B", I think this is safer but am I giving up Horsepower??? THANKS
Jeremy
Two turbos and a carb...
P.MUSSIN is offline
post #2 of 2 Old 03-06-2003, 10:45 PM
Locked out would give you better off idle throttle response. Of course, if you run into pinging when lugging the motor, then you need to use a spout connector. I have seen some streetable serious cars who like running with the timing locked out.
Blown347hatch is offline
