2014 Coyote twin turbo - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By 1994Musturd
post #1 of 8 Old 07-28-2017, 10:03 AM Thread Starter
I have a 2014 Mustang Cali Special with dual On3 twin turbos. I bought it with a blind tune. Driven the car 600+ miles with a couple passes down the strip and the O2 sensors are still not going ready, and I have a reject sticker. I have a simple scanner and I'm getting live data from the sensors but I need they are not completing the drive cycle readiness. I live in Western Mass are there any tuners out there that can help me figure this out? I took the car to the track on Wed and I now have a misfire. Not sure where to start...
JDubb23 is offline
post #2 of 8 Old 07-28-2017, 10:07 AM
Do you have cats?
1994Musturd is offline
post #3 of 8 Old 07-28-2017, 10:35 AM Thread Starter
No cats. Car was tuned by Dan at Real Speed in NY. When they were returning my phone calls they said the tune had the O2s active.
JDubb23 is offline
post #4 of 8 Old 07-28-2017, 10:55 AM
without cats the rear o2's are probably turned OFF so they'll never complete the readiness cycle. You need the rear o2's turned on (and likely use cats or a "another method") for it to complete the readiness check.
5.0thunder is offline
post #5 of 8 Old 07-28-2017, 11:21 AM Thread Starter
I'm getting live data from the O2 sensors when I plug in my cheap hand held scanner. If the rear O2s were turned off I don't think I would get and data. I think I need to start data logging. What do I need to data log this car?
JDubb23 is offline
post #6 of 8 Old 07-28-2017, 11:29 AM
Bingo
Those O2's need to see the correct heat range too.
5.0thunder likes this.
post #7 of 8 Old 07-28-2017, 11:48 AM Thread Starter
The tuners verified they are on. How do I determine if the heat range is adequate?
JDubb23 is offline
post #8 of 8 Old 07-28-2017, 11:48 AM
Likely getting data from the front o2's, which I believe are wideband in these cars (they are on the GT500's, i know that much). When you remove the cats, tuners will turn the rear o2's off so the car doesn't throw a code. the fronts are still ON and needed for fueling.
Reliable twin turbo? Crabro88 S-197 Mustang (2005-2010) 6 04-27-2013 12:22 AM
built Twin Turbo Coyote Nastystang06 S-197 Mustang GT (2011-2014) 1 05-30-2012 12:50 PM
For Sale 1995 25.5 Twin Turbo Outlaw Drag Radial Mustang [email protected] Mustangs For Sale/Wanted, 1994-1998 11 11-23-2011 11:17 PM
