Where can I get quality clamps? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 02-01-2003, 03:43 PM Thread Starter
Emerald's Avatar
Question Where can I get quality clamps?
One of my clamps busted coming of the turbo . I checked the cartech website but didn't see anything. I just put a regular hose clamp for temp fix. I know it's not good for the sillicon hose but I didn't tighten too tight. I tried searching and found some t-bolts at summit but just wanted to ask other's. Thanks. -Jeff
Jeff
88 White notch.
04 VRSCB- Air ride, PM wheel, PCIII, Rineharts and much more!!
Emerald is offline
post #2 of 9 Old 02-01-2003, 04:16 PM
what do you need we have several different types
Carson is offline
post #3 of 9 Old 02-01-2003, 06:47 PM
Re: Where can I get quality clamps?
Jeff, we can get you replacments for whatever you need. You can PM, e-mail, or give us a call 210.333.1642.
Thanks,
Preston
Cartech Preston is offline
post #4 of 9 Old 02-01-2003, 08:25 PM Thread Starter
Emerald's Avatar
Thumbs up
Sent you a PM Preston.
Jeff
88 White notch.
Emerald is offline
post #5 of 9 Old 02-02-2003, 04:23 AM
Is there a certain type you should use? My kit just has normal clamps I thought? I would assume its ok as long as they aren't the type that have small square holes in them all the way around?
I picked up a couple clamps when I had to do a few things after the kit was installed...should I change them to the type that is solid the whole way around?
Red '86 GT w/T-Tops, Cervini-Mach I Hood, Cervini Fiberglass hatch, Cervini fiberglass cobra wing, FMS 302 SVO Shortblock,Explorer Cam,Crane 1.7 Rollers,FMS-Double Roller timing chain, FMS 65mm Throttlebody, Cobra Intake Upper/Lower, FMS GT-40 ported iron heads, Dynamax exhaust, FMS Aluminum Adj.quadrant, FMS SVO T5 World Class, Hurst w/aluminum(line lock) T-handle, FMS Aluminum Driveshaft, FMS 3.73 Gears, M-1007-C58's (FMS Chrome cobra R's) all way around on BF 245-45-17's. 5 lug 13" front 12" rear baer system, MM Adj. lower control arms, MM full length subframes, Battle boxes.
DFI Generation VII w/wideband
2 Bar MAP (added 5/31/02)
T3/T4 Twin Turbos, MSD 6A, Seiman Deka Low Impedence 55# Injectors, Walbro 255 lph GSS340 pump
mustang8650 is offline
post #6 of 9 Old 02-02-2003, 05:06 AM
t-bolt clamps work pretty well.
psikillz is offline
post #7 of 9 Old 02-02-2003, 05:52 PM
blackholehunter's Avatar
If you don't want to wait for mail order on the clamps you can probably get some t-bolt clamps at a local diesel shop.
2003 FFW Drag radial Champion at Palmdale, CA
1991 LX- 9.88 at 138.5 1.51 60ft on 28X12.5 et streets
10.83 at 132.94 1.92 60ft on Drag Radials
blackholehunter is offline
post #8 of 9 Old 02-18-2003, 12:10 AM
GaryJ's Avatar
Cat, yes that Cat, uses some nice clamps on their tractors that you could buy if there is a dealer near you. I have them on both ends of my discharge tube and they are much better looking than you will find at a hardware store. Very nice.
JMO.
GaryJ is offline
post #9 of 9 Old 02-22-2003, 10:06 AM
znaut's Avatar
Actually you can order T bolt clamps at NAPA.
znaut is offline
