Fuel system for On3 kit and e85? - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By KEVIN$
post #1 of 8 Old 05-11-2017, 10:46 AM Thread Starter
Okay guys I'm planning on buying an on3 kit to throw on my 91 gt. I need some info on what you guys are running mainly fuel pump wise.
Current setup:
Built 347
10.5:1 CR
Performer RPM heads with valve job
Vic Jr. Intake modded for fuel injection
EFI Spyder elbow
Etc.
Current fuel system:
Aftermarket pump hanger with 3/8" feed and return tubes and proper AN fittings at the hookups
-8an feed line
-6an return lines
Billet rails
36lb injectors
Aeromotive regulator
Aeromotive Stealth 340 IN TANK pump.
I'm almost positive I'll have to go e85 if I put any boost to this motor due to my compression ratio being a little on the high side. My main concern is fueling at that point. I know I'll have to probably go with 80# injectors possibly even bigger. But what I'm most curious about is if my current Stealth 340 pump would be enough to support 500-550 RWHP on e85. I really would like to stay with an in-tank pump so I don't have to redo everything. Would a Boost A Pump give it the extra grunt it may need to fuel this thing? Or any other pump options for in tank? Must be a single pump though as my tank is only set up for a single.
Please chime in with your opinions guys.
Suzukikevin95 is offline
post #2 of 8 Old 05-11-2017, 11:39 AM
Is this a stock block? If so, all you need is siemens deka 60lb injectors to make block splitting power on e85 (over 600 crank) using your existing pump (if its rated for e85). If you have an aftermarket block, you can make about 850 on Siemens deka 80's with a walbro 450 in-tank. If you want more, you're looking at big external pumps and big injectors (120's or 160') in order to make anywhere from 1000-1500+.
To be on the safe side, or if your current pump isn't rated for e85, I'd go with a set of 80s and the walbro 450 pump now. That way you have plenty of fuel and room to grow if you want an aftermarket block. The pump is only like 100-120 bucks and the 80's can be had for the same price as the 60's.
I use the 450 and 80's in my car on e85 and it's been fine.
5.0thunder is offline
post #3 of 8 Old 05-11-2017, 11:47 AM Thread Starter
Yeah it's a stock block. Just want to push it to the limit and then back it off just a hair and be safe lol. The Stealth pump has been revised and is now good for e85 so with that being said all I'm looking at is an injector upgrade? I doubt I'll ever be in a spot to go with a crazy setup so I'm not too worried about having headroom on the pump and whatnot.
post #4 of 8 Old 05-11-2017, 12:45 PM
Then yeah, basically a set of 60's will let you blow the block apart. lol
post #5 of 8 Old 05-11-2017, 01:15 PM Thread Starter
Haha sounds good to me! I don't wanna scatter it but I definitely wanna get 500 wheel out of it. Mainly so I can say I did it, have a story for future son lol, bragging rights over a couple buddies etc. car currently runs 7.60 in the 1/8th on street tires and leaving at idle through a t5 and i would like to see 6s
post #6 of 8 Old 05-13-2017, 10:48 AM
Trader Feedback: (21)
I would​ be more concerned about the line sizing more than the injectors or pump. There are some calculators out there to help you.
For everything that is worthwhile, there is a counterfeit.
boostup89 is offline
post #7 of 8 Old 05-14-2017, 04:06 PM Thread Starter
I've got -8AN feed lines and -6AN return to an aftermarket hanger with the larger sized return tube as well. I would think that would be plenty
post #8 of 8 Old 05-14-2017, 04:45 PM
KEVIN$'s Avatar
-8 feed will be fine.
ks
Suzukikevin95 likes this.
Kevin Slaby
KEVIN$ is offline
For Sale Complete Turbo/Supercharger Fuel System MavStang Fuel System & Related 4 06-22-2015 11:40 AM
For Sale e85 return fuel system 1000cc bosch injector dbmustanggt Fuel System & Related 1 10-24-2014 01:06 AM
For Sale Fore Innovations Fuel system E85 nosnation.com Fuel System & Related 5 03-12-2014 11:22 PM
E85 - modifying carbs and fuel system hkopp 5.0/5.8 Engine Tech 3 01-13-2014 10:30 AM
E85 Fuel System Questions slo284 GT & SOHC 5 02-17-2011 09:15 AM
