pmas transfer function help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 05-02-2017, 06:40 PM Thread Starter
http://www.pmas-maf.com/wp-content/uplo ... /hpx-e.xls I changed the pipe size to 3 inch to give me flow but what do I use for voltage readings ? I see tube size but how do i figure tube area is that what is used to come up with voltage? what is the first scale
boosted363 is offline
post #2 of 4 Old 05-04-2017, 01:33 PM
Trader Feedback: (21)
When I did mine I entered the 30pt transfer function for the pipe size. It was somewhat close, but still required some dialing in. What are you tuning with?
For everything that is worthwhile, there is a counterfeit.
boostup89 is offline
post #3 of 4 Old 05-04-2017, 05:26 PM Thread Starter
quaterhorse
post #4 of 4 Old 05-04-2017, 09:05 PM
Try out EFIDynoTuning it's an absolute life saver. And Decipha will be glad to see you run Quarterhorse.
Transfer function for 80mm PMAS tube waltnono 5.0/5.8 Engine Tech 13 01-20-2016 03:11 PM
MAF Transfer Function and Calibration Pro-M Efi turboLXstang Engine Management Systems 18 12-14-2015 10:07 AM
Pro-M 80MM transfer function sheet, 60lbs Psychostang General Mustang Tech 3 12-30-2010 10:30 AM
MAF transfer function BrianW 5.0/5.8 Engine Tech 8 12-21-2001 11:37 PM
