Need help on fuel system and ignition set up? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 01-29-2003, 02:26 AM Thread Starter
Coilz347's Avatar
Im in the process of rebuilding my stock motor in my 89 coupe, and getting it ready for a major hp, and tq boost. What id like to know is what should i do for the fuel system?
This is whats going on the motor, stock bottom end, with ported dart senior heads, with 2.02/ 1.60 valves, stock cam with 1.72 stud mount rockers, trick flow intake, and a stage two twin turbo from ITS.
As for my fuel system i have a set of 24lb injectors and a 255lph in tank pump,
I already have a aeromotive 1000hp pump, and im getting my stock gas tank sumped tomorrow, but what size injectors should i go with? And will i need new fuel rails?
what type of ignition are u guys running with your power adders?
So far all i have is a msd 6al?
What do u guys recommend?
Coilz347 is offline
