Is a .68 exhaust housing too small - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 03-27-2017, 02:32 PM Thread Starter
t32265's Avatar
I am running twin 70mm turbos on my 363 sbf and am just wondering if my current housing are too small. They spool very fast and just thinking they might be causing excessive back pressure, what are you thoughts?
t32265 is offline
post #2 of 7 Old 03-27-2017, 04:27 PM
hard to say on a motor that "small". does it have a good flowing head/cam? you probably could make some more power with bigger housings but you'd be best off actually doing some calculations or talking to a supplier/manufacturer. how quickly is it currently spooling? where does it make full boost?
5.0thunder is offline
post #3 of 7 Old 03-27-2017, 05:09 PM Thread Starter
t32265's Avatar
Heads are AFR 205 renegades, and cam is custom solid roller 656/653 248/252 @ 114.2 lsa, have not built to full boost yet but will build 12# on the brake at 4200 and still ramping up.
t32265 is offline
post #4 of 7 Old 03-31-2017, 06:28 AM
wytwolf's Avatar
Sounds like you're gonna pumping some air! Talk to your cam guy. I think it'd be a bit small.
wytwolf is offline
post #5 of 7 Old 03-31-2017, 03:48 PM
pkstang's Avatar
Trader Feedback: (161)
what are your EGTs?
pkstang is offline
post #6 of 7 Old 04-02-2017, 08:13 AM
turbostang90's Avatar
More info on the turbo may help. Exducer wheel size, DP diameter size?
But im strongly leaning towards, yes. That is to small.
TurboFox 331 Billet S476 FB AODE
turbostang90 is offline
post #7 of 7 Old 04-11-2017, 10:48 AM Thread Starter
t32265's Avatar
Its twin on three 70mm turbos, but i think i will just have to fab up something to measure back pressure.
t32265 is offline
.68 or .81 A/R exhaust housing? MYSTICSVT Turbochargers 4 11-22-2012 09:09 AM
Want To Buy .68 ar exhaust housing for masterpower turbo impakn Power Adders 2 11-09-2012 10:35 AM
!!!CAUTION!!! Controversial Topic: How true is this? 8th paragraph My95tang5.0 SVT & DOHC 40 08-02-2012 07:45 AM
Want To Buy WTB: Masterpower t70 turbo with .68 exhaust!!! shakenbake16 Power Adders 1 09-24-2011 04:02 AM
WTB:On center exhaust housing, MPT-70 Dunn1 Power Adders 0 01-21-2007 03:58 PM
