I test fitted my TT setup.. - Ford Mustang Forums : Corral.net Mustang Forum
 11Likes
post #1 of 100 Old 03-04-2017, 04:46 PM Thread Starter
midnightlaundry's Avatar
Everything fits real good. It will be easy to finish the exhaust. I'll use the tail pipes for a stock look.
The Turbos are in a good spot, so I think I can fab up some Rod End type supports with some round tubing. One on top and one on the bottom somewhere to triangulate them to the motor and relieve the weight on the Headers. Still need to do that!
midnightlaundry is offline
post #2 of 100 Old 03-05-2017, 12:42 AM
Trader Feedback: (21)
CX hotside?
boostup89 is offline
post #3 of 100 Old 03-05-2017, 05:28 AM
I'm interested in more details on the kit and turbos also.
kbscobravert is offline
post #4 of 100 Old 03-05-2017, 09:36 AM
Looks like a CX. I've heard some good about their latest kits. Weld quality was good and figment was good as well.
HLD-TYT is offline
post #5 of 100 Old 03-05-2017, 10:32 AM Thread Starter
Yes, It's CX. They have a new Single kit out with Dual Gates that looks cool. That would be way easier to work out. I might have done that if it was out at the time I bought, but the cool factor of TT's is hard to beat. Plus, I the car is intended for Street, so 2 smaller Turbos will get up on the Boost faster then 1 big hog.
One thing to mention is the Oil Drainback parts included are too narrow. I eBay'ed some larger -10 parts without to much trouble or extra expense. I'm working out the details now before I get the motor in the car so I don't have to deal with these problems latter. But so far, things are going good.
Here's some links for you guys.
Turbo Header Manifold Intercooler Kit For 79-93 Ford Mustang V8 5.0 NA-T T76
GT35 Twin Turbo Intercooler Kit For 79-93 Ford FoxBody Mustang 5.0L Dual 900 HP
post #6 of 100 Old 03-05-2017, 11:22 AM Thread Starter
Here's the Bulkhead style pan fitting that came with the kit compared to a real -10 weld in Bung.. No smokin' Turbos for me..
post #7 of 100 Old 03-05-2017, 11:26 AM
Here's the single turbo hotside from CX racing. I have seen this header kit on two other cars, and both had been beat on like most race parts are. After several years they were both in great shape. For $385 to my door, I can't begin to build for that.
post #8 of 100 Old 03-05-2017, 08:40 PM
I almost pulled the trigger on the TT kit, I'll have to sit and anxiously watch yours come together.
post #9 of 100 Old 03-06-2017, 12:46 AM Thread Starter
I put some front dress on, and am happy to say that the 3G Alternator clears! However, these Fuel Rails I have clear the Distributor on the right side, and that's all I can say at this time..lol.. Really tho, I think I can work it out. I'll need to open up the bottom Distributor shell and seal it up somehow to make room for the 180 degree fittings I plan on running back to the Regulator I bought..
Don't worry, I'm going with Silver on the AC Compressor because the Blue looks like crap.. I used to like it. Now I don't. I'll go silver on the Valve Covers as well. I want the motor to POP when you look at it..
Here's the old motor.
I need to work out the plumbing for the Water Cooled Jackets on the Turbos.. There's no way I'm not running them.. But the way they the Banjo Tubes are bent, I can't seem to get a good angle on then to the center of the motor. I think I could chop them where they are bent and just weld on AN fittings if I can find them in steel. This would make it cake to plumb into the Heater Core lines.. Lots to do..
kbscobravert likes this.
post #10 of 100 Old 03-06-2017, 07:38 AM
97stanger97's Avatar
Looks great man. What are your goals for the car?
1997 Mustang GT
1997 Mustang GT
10:1, TF heads, Turbo cams, 7675, E85, 4R70W, Holley EFI
97stanger97 is offline
post #11 of 100 Old 03-06-2017, 08:15 AM
Sweet. How hard will it be to access Spark plug #1 and 2?
5.0thunder is offline
post #12 of 100 Old 03-06-2017, 08:27 AM
Where/how do you run the turbo coolant lines?
post #13 of 100 Old 03-06-2017, 05:08 PM Thread Starter
Quiet and reliable sleeper Street Car. Corvette Killer..
post #14 of 100 Old 03-06-2017, 05:19 PM Thread Starter
It's not happening on either side.. The Down Tube needs to be moved. But it seems like you can just removed the bolts from the Turbine and rotate it out of the way after loosening the V-Band Clamp.
It shouldn't be a big deal. I should be able to just position the Clamp so I can reach it with an extension under the car without having to jack it up. That is the plan anyway..
5.0thunder likes this.
post #15 of 100 Old 03-06-2017, 05:26 PM Thread Starter
Garrett has an informative article on the subject..
https://www.turbobygarrett.com/turbo...er_Cooling.pdf
post #16 of 100 Old 03-07-2017, 08:15 AM
Are you tuning the car? Will it be on gas? I went through like 3-4 sets of plugs getting a decent tune on gas. Had to pull them all the time with hardly any miles on them. It becomes a big pain if they're not real easy to get to. Hopefully you have good luck
midnightlaundry likes this.
post #17 of 100 Old 03-07-2017, 12:35 PM Thread Starter
Yep, Pump Gas car. it is what it is.. I'm all in at this point so there's no turning back..lol
post #18 of 100 Old 03-07-2017, 01:26 PM
Lol let's just hope it's dead on from the get go.............
post #19 of 100 Old 03-07-2017, 02:00 PM
build thread?
post #20 of 100 Old 03-07-2017, 11:41 PM Thread Starter
No Build Thread yet. I'll wait until I have the motor in the car. That won't be for another month or so while I work out these little details, and the weather warms up a bit!
post #21 of 100 Old 03-08-2017, 08:12 AM
How dare you tease with mockup pics
post #22 of 100 Old 03-08-2017, 12:13 PM Thread Starter
I just ordered all my AN Fittings and Hoses so I can plumb everything. It will probably take a couple weeks to get them, so there's not much to see at this point.
After that tho, I'll get some car shots and get things moving on this build.
post #23 of 100 Old 03-08-2017, 07:31 PM
t32265's Avatar
installed their twin headers on my SN95, the sparkplugs are near impossible to change, and am having issues melting plug wires, I did cut the t3 flanges and installed t4 flanges. I am running 70mm turbos with turbosmart 38mm racegates. I will be removing the cx racing headers and putting ponydown on within a month. A few header bolts a real hard to get at but I am also running 3" downpipes. I have thought about just adding an inch to each pipe by flanges but easier to buy new stuff.
t32265 is offline
post #24 of 100 Old 03-08-2017, 10:15 PM Thread Starter
Sorry to hear that. I'm not sure how different an SN95 is tho..
Did you wrap your Downtubes?
post #25 of 100 Old 03-09-2017, 03:04 PM
t32265's Avatar
Yes wrapped everything, just headers are so tight to the block there is no room for plugwires and to change plugs, you may be alright but at my power levels not being able to change my sparkplugs or even reading the plugs is not acceptable. i can text you pictures if you would like. 3862168593
t32265 is offline
post #26 of 100 Old 03-10-2017, 02:46 PM Thread Starter
Post em in this thread so we can see what's doin..
post #27 of 100 Old 03-12-2017, 07:31 PM
t32265's Avatar
Wont allow attachments, or I would have already.
t32265 is offline
post #28 of 100 Old 03-12-2017, 07:51 PM
t32265's Avatar
t32265 is offline
post #29 of 100 Old 03-14-2017, 11:13 AM
Here you go man
post #30 of 100 Old 03-14-2017, 08:13 PM
Here you go man
That looks like a sack full of F-bombs to change those plugs.
post #31 of 100 Old 03-14-2017, 08:50 PM
t32265's Avatar
Thank you can see the issue with plugs.
t32265 is offline
post #32 of 100 Old 03-14-2017, 10:19 PM
Lol yeah best thing i can think of is a ratcheting wrench. otherwise that plug would never get changed on my car. hah
post #33 of 100 Old 03-15-2017, 10:20 AM
I see what you've saying about the plugs/ wires.
You going to go single in your new pony down setup?
Reason I ask is I'm thinking about switching to twins to help me reach my goals.
But honestly my single spools so fast now, plugs are easy, gravity oil drain...I'm just not fully committed to change from single to twins.
Meegs is offline
post #34 of 100 Old 03-15-2017, 02:11 PM
I always run all plug wires from the bottom. I drop them down behind the AC and alternator then down along the engine to their respected spot. I also put on the Heat boots. No issues....
HLD-TYT is offline
post #35 of 100 Old 03-15-2017, 08:46 PM
t32265's Avatar
No, I am staying with twins, and in future will be using PTE 67/66 and pony down stage 3 headers. I love that the turbos don't have to work hard and that keeps the IAT down, and I have also tried to run the wires underneath but there is no room for that, I have always ran them underneath with my single turbo set ups prior to this incarnation.
t32265 is offline
Wilwoods new AERO6 calipers and 14x1.25 setup LT1HAHA Road Racing/Auto X 27 12-06-2016 09:17 AM
Want To Trade WANTING TO TRADE A BRAND NEW 76MM TURBONETIC BALL BEARING COMPLETE TURBO KIT FOR A BLOWER SETUP 88NotchBlown Power Adders 2 03-12-2016 04:54 PM
okay to run cylinder balance test and some other tests with known headgasket failure? killer5-0 General Mustang Tech 8 03-03-2016 09:44 AM
For Sale 347 Forged Dart Stroker Motor setup for boost CATALYST Windsor Engine Parts 9 08-18-2012 11:46 PM
For Sale Complete race cog setup w/ many extras for Procharger 4.6 eebj01 Power Adders 7 10-07-2011 08:08 PM
