surge limit for Incon turbos?? how little boost can i run? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 01-25-2003, 04:34 PM Thread Starter
Im working right now on getting my new motor together, the combo is in the sig. The rebuilt bottom end is all i can afford now, so i want to try to keep it together untill im out of school. I just bought the Keith Craft Tw's the other day, they flow 280in @.600 and 240ex @.600.
I got these for 2 reasons. 1, i wanted a little more detonation resistance than my ported irons since these are aluminum. 2, Im hoping that since these flow so well i can make the same power i was making before with less boost so it will last a bit longer, or atleast help keep detonation out of the picture.
I was running 10 psi before with hogged out E7's and a stock cam. Do you think i can run 6 or 7 psi and still make comprable power with my new set up? Most importantly, am i nearing the surge line for the GTBB35's? I havent ever seen a compressor map for these.
Think 500hp/500tq at the wheels is possible wiht this combo and 6-7psi of boost?
thanks everyone,
Shaun
393"/twin T70/full accessory/billet ITB intake/stock hood/alum. 3.5" exhaust
Shaunthony's: you're gonna want to wear a cup
CobraSC is offline
post #2 of 3 Old 01-27-2003, 08:54 AM
Shaun,
Those turbos make good mass airflow at low pressure ratios, but not enough to make 500rwhp at 6-7psi. You'll probably want about 10-11psi to make that. You can run them all day long at 6-7psi and be nowhere near the surge limit, though.
Shane Hill
90lx with a 304ci 4v, Turbo400, and 105mm turbo
Thanks to TranzKing, MMR, BS3, Don Bailey, Team Z, and Wolfe Racecraft
NoSlix is offline
post #3 of 3 Old 01-27-2003, 04:58 PM Thread Starter
Ok, thanks Shane. I guess ill just start with 6-7psi for now and work my way to around 10-11psi as my faith in the stock bottom end and my tuning skills increases...
Thanks,
Shaun
CobraSC is offline
