Turbo 5.4L - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 01-19-2003, 09:24 PM Thread Starter
Turbo 5.4L
I am installing a T63E on my F250 with a 5.4. I am using Ford 42# injectors, C&L 85mm mass air meter Holley billet fuel rails, Walbro 255lph pump, Areomotive regulator, Superduty intercooler, and was planning on about 8-9lbs of boost. My question is can I get away with 5 lbs. of boost and the stock computer with no chip by simply boosting fuel preasure to keep the air fuel ratio at a safe level until I can get a custom chip burned on a dyno. Also what spark plugs would be best used in this application.
carbuffiam is offline
post #2 of 15 Old 01-20-2003, 06:04 PM
Sounds like a fun truck, need a chip though, I wouldn't trust the MAF and FPR.....
CKMustangCobra is offline
post #3 of 15 Old 01-20-2003, 06:44 PM Thread Starter
I know I can't wait. I got this sick feeling to throw it into four-low and see what she'd do on dry pavement, now I can't wait to see what the added Hp. does to that, set you back in the seat feeling. I know of a few Slomaros and Top fuel Hondas that are going to be real sorry stop light to stop light that they messed with this 4 wheel drive. HeHeHE
post #4 of 15 Old 01-20-2003, 06:56 PM
P.MUSSIN's Avatar
I don't see why you couldn't... I ran 9psi with my stock computer just using a Kirban ADJ reg., and tuning by checking the plugs.
Jeremy
Two turbos and a carb...
P.MUSSIN is offline
post #5 of 15 Old 01-23-2003, 09:32 PM
Thumbs up Here
Call Keith @ ProTurbo kits. http://www.proturbokits.com
They did a twin-turbo truck not too long ago and it's still sitting in the shop.
-Nate
'98 Cobra Coupe
Streetracer is offline
post #6 of 15 Old 01-23-2003, 11:25 PM
Founder corral.net
Christopher Ihara's Avatar
I don't believe you're going to be able to regulate the fuel pressure with the regulator you have. 1999+ vehicles are returnless fuel system vehicles. I'm not sure about trucks, but I'm fairly certain that they too are returnless.
This means that you're going to have to regulate fuel pressure with a chip. You may do better off with a Lightning fuel tank and pump assembly. This will give you all the fuel pressure and volume you need.
I'm not sure if that will fit in your application, however, the pump may fit in the tank.
"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety." - Benjamin Franklin
Christopher Ihara is offline
post #7 of 15 Old 01-24-2003, 04:58 PM
Im going with Denso Iridium IT20's. I heard that they are the best so you may want to give them a try. Quite a few lightning guys are using them on there trucks so they should work nicely on yours.
mrstumple is offline
post #8 of 15 Old 01-28-2003, 07:33 PM
NGK TR6 plugs saw me well over 700hp and 14psi.
TenSecondSnake is offline
post #9 of 15 Old 01-29-2003, 12:13 AM
EvilTwistedTwins's Avatar
Re: Here
"Nitrous is like hot girl with with STD's. You know you wanna hit it, but your afraid of the consequences."
EvilTwistedTwins is offline
post #10 of 15 Old 01-29-2003, 02:11 AM
What about using a lightning computer and MAF? we've all seen the kind of power and drivability they can have at increased boost levels, wonder how that would translate to the turbo truck.
I would think it'd be a good start at the minimum.
WaterPog is offline
post #11 of 15 Old 01-29-2003, 02:12 AM
man it's getting hard to tell if a post goes through on this server lately.
WaterPog is offline
post #12 of 15 Old 01-29-2003, 10:51 PM Thread Starter
Thanks for the spark plug info and Superduty Trucks have a return line fuel system similar to the ones used on 5.0L Mustangs in the 90's. And a matter of fact I bought the AN adapters for fuel and return lines that fit 90's Mustangs so I could install my regulator and after market fuel rails.
post #13 of 15 Old 01-30-2003, 12:21 AM
Question Ummm
Was there something comical that I missed about my post?
-Nate
'98 Cobra Coupe
post #14 of 15 Old 01-30-2003, 07:11 AM
Re: Ummm
ahhh i just hate everything about PTK you just have to know the story behind it
post #15 of 15 Old 01-31-2003, 09:45 AM
Thumbs up Ahh
Gotcha. I think I read something about it a long ways back in a thread that got locked.. I spoke with Keith and I believe he mentioned that the individuals on The Corral badmouthing the PTK pieces had never even bought one. I saw the work first hand and it is top quality. He also beat the price of Total Performance's kit by a large margin, using all quality stainless hot parts as well and a 6" thick air-to-air intercooler as well.
-Nate
'98 Cobra Coupe
