302 exhaust temp cylinder to cylinder - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By DevaRoh2.0
post #1 of 3 Old 08-21-2016, 05:32 PM Thread Starter
Curious what kind of temps I should see coming directly out of the head into the primaries at idle?
302, trickflow twisted wedge 170's, f303 cam, explorer upper/lower intake, 42lb injectors, single 70mm turbo
wytwolf likes this.
DevaRoh2.0 is offline
post #2 of 3 Old 08-22-2016, 08:55 AM
TomR's Avatar
There is far too much going on at idle for there to be any single answer.
Header surface area, compression, header thermal conductivity, cam overlap, flow restriction, mixture, fuel consumption, and ignition timing all have a large influence.
Street driving my car without excessive under hood pipe and turbo heat required a stoichiometric mixture and around 28-30 degrees advance. The main thing I worried about was all the heat from the pipes and turbo.
TomR is offline
post #3 of 3 Old 09-05-2016, 07:30 PM
Its a tricky question to answer. I fought with this in the past and tried several IR temp guns. Ended up buying a Fluke adjustable one (pretty sure its this one and bought add on temp wire plug-in Contact Thermometer | Fluke 561 Infrared and Contact Thermometer ). Was told 10 different things by 5 different people it seemed. Coated vs uncoated vs which coating, 1inch from head vs straight vs bend, cold vs running temp, idle vs mid throttle vs full load, list went on. Biggest thing was to look at it like a compression test. Look for something different/out of place, keep track of any changes. With that said there is a general temp range that should be acceptable. I don't have my records with me but 400F seems around norm. Of course, in a perfect world individual EGT probes would be best.
In my experience it has proven to be a quick an easy tool and was capable of finding a broken valve spring.
Here is a little write up
When Do Exhaust Gas Temperatures Become A Cause For Concern?
COP TZR is offline
For Sale 302 with t5 and exhaust robsnodz Windsor Engine Parts 9 10-12-2013 11:44 PM
Can a turbo charger be used to increase MPG? BRYAN ROGERS Green-Rodding 152 10-02-2013 04:07 PM
For Sale BOSS 302 CYLINDER HEADS AND INTAKE mustang500hp Windsor Engine Parts 14 05-20-2013 08:49 PM
Want To Buy WTB: Boss 302 quad exhaust system UltraKla$$ic S197 and Coyote Parts 0 07-01-2012 04:27 PM
94 gt 302 supercharged surging and stalling when it reaches running temp jstang88 94/95 Tech 0 01-28-2011 07:09 PM
