Question about choosing OTS camshaft - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 05-06-2016, 09:45 AM Thread Starter
BlowThisRacing's Avatar
long story short I bought the car as a partial roller with no top end on the motor. It has a stage 2 TFS camshaft. I went to a single 60mm turbo set up and this cam is not good for my turbo set up. The motor is coming out in a couple months and I was going to replace the cam with something a little more turbo friendly. this is on a 5speed stick shift car. Looking to have my boost kick in a little faster. I know custom grind is the way to go but I'm not spending $400+ for one on a stock block. My set up is this:
TFS 170's
Stock bottom end 302 including block
TFS stage 2 cam
60mm Turbonetics turbo running 11 psi
I have access to a used Anderson b31 for a good price just wondering if it's a good cam for a turbo or not. Heard it was for SC. Looking for experiences with cam's on motors that are 302/306 based to get me in the ball park. Thanks
BlowThisRacing is offline
post #2 of 4 Old 05-11-2016, 08:36 AM
Trader Feedback: (59)
I would not prefer to run a b31 because it is ground more for a supercharger setup. Find a simple F303 cam, it works well with a turbo with it's 114 degree lobe separation
prddad1 is offline
post #3 of 4 Old 05-13-2016, 01:31 PM Thread Starter
What springs are good with the F cam?
post #4 of 4 Old 05-18-2016, 03:20 PM
mrjay1979's Avatar
i run f cam on my turbo car, i have tfs heads
1994 gt-on3,trick flows,f cam, systemax intake, 530/520
mrjay1979 is offline
Custom FTI solid flat tappet camshaft 351w 6t9mach1 Windsor Engine Parts 5 11-28-2014 04:02 PM
Help Wanted! PLEASE Read. (BLOWER CAMS) MARK 302 Superchargers 53 02-24-2012 09:51 PM
Man facing jailtime for owing child support commits suicide on courthouse steps MurPHy4570 Politics 96 02-19-2012 01:24 PM
Using Hyd. Flat-Tappet Lifters on a Solid Camshaft? And Comp cam 35-609-5 question Bughracing 5.0/5.8 Engine Tech 8 12-09-2001 03:24 PM
Camshaft Question 93yelLE 5.0/5.8 Engine Tech 4 11-30-2001 09:36 PM
