500 rwhp on 6-7 psi - Ford Mustang Forums : Corral.net Mustang Forum
 5Likes
  • 1 Post By Gear Slammer
  • 2 Post By boostup89
  • 2 Post By mrjay1979
post #1 of 9 Old 04-10-2016, 11:28 AM Thread Starter
500 rwhp on 6-7 psi
Im wanting to add boost to reach about 500 rwhp but keep the stock block for now. Id like a turbo that will do well at 6-7 psi on the stock block but still have lots of room to grow once i can complete a dart 331 build. Keep in mind i DONT want to lower the 11.1 compression of the stock block. This car will be a race gas only car. Id like 500 rwhp for stock block, but potential for 750+ rwhp later.
There will be some changes made to make this switch.
1. Add a dss girdle to block for now
2. Swap n91 for boost cam (opinions ?)
3. Larger injectors
Which turbo?
Which cam?
Thx
93 LX. stock block. 11.1 comp. scat 331 w/ stage 2 ported TW 170's, TFS-R series intake, afm n-91 cam w/ 1.6rrs, afm 4" powerpipe ProM 75mm maf w/ Accufab 75mm tb, 1 5/8 LTs w/ 2.5" X-pipe and flowmasters, 3.73s, 30# inj. 368/350 with safe tune
YelaGN is offline
post #2 of 9 Old 04-13-2016, 09:41 AM
Trader Feedback: (21)
Save your money on the girdle it won't help, the compression and cam are currently paired fairly well, I don't know the correct answer on how to change one and not the other.
boostup89 is online now
post #3 of 9 Old 05-04-2016, 01:51 PM
Gear Slammer's Avatar
So here's what I've got right now. I believe it pretty much matches your goals. Will give you ideas.
Stock bottom end freshened and zero decked. Main ARP studs. ARP wavelock rod bolts.
Trick Flow Track heat HCI upper engine kit. ARP head studs.
Trick Flow stage 1 cam.
On3 70mm turbo kit.
42lb injectors.
255lph high pressure fuel pump.
70mm Accufab TB
Blow through MAF welded into cold side.
Safe 91-92 octane pump gas tune.
6 psi spring in wastegate.
See my signature for numbers @ the wheels. I have now put over 4k miles on this setup. On3 wastegate was leaking slightly and stuck open twice. Replaced with Precision gate. Put in the '7.5 psi' spring, now seeing 8-9psi on a longer pull. Goes like crazy!! Significant increase @ high boost levels...probably around 500rwhp.
DreadFox likes this.
1989 5.0 GT / Trickflow HCI / 70MM On3 kit
414 HP / 409 Ft Lbs on 6 PSI @ 5,500 on APS tune!
Gear Slammer is offline
post #4 of 9 Old 05-04-2016, 05:57 PM
11:1 compression??? I believe that the stock block with stock heads is 9:1 compression. Do you have some different heads and/or pistons in your motor?
post #5 of 9 Old 05-05-2016, 01:44 AM
On3 70mm turbo kit.
42lb injectors.
70mm Accufab TB
We have matching cars, lol. I have a 89GT, factory block TrickFlow top end kit with Systemax intake, On3 70mm Kit, 42's, 340 pump, drop in Pro-M Maf and PMS-4 for tuning. Hoping to hit 500rwhp around 10psi.
-1989 Mustang GT
On3 70mm turbo kit, TrickFlow top end kit, Holley Systemax intake, Astro A5 T5, 3:55's, lots of bolt ons.
99gt04 is offline
post #6 of 9 Old 05-06-2016, 05:11 PM
Wondering how you like your Astro A5 trans?? I was checking out their website. Wondering how you came to the A5 as a choice? I was looking at Tremec TKO line, but maybe the Astro is the way to go??
I rebuilt my trans with D&D perfromance rebuild kit with heavier input shaft, 2nd and 3rd gears, and 2nd 3rd gear counter shaft. So far it is holding together, but who knows...??
post #7 of 9 Old 05-06-2016, 05:42 PM
I only have a handful of miles on it but so far so good. Shifts great with a MGW shifter. I came across a killer deal on here for a brand new A5 about an hour away so I went and bought it. Mine has a G Force case as well and says it's rated at 600tq. Seems like a lot of people have good luck with Astro. If it ever goes then I'll most likely go auto with the turbo set up.
99gt04 is offline
post #8 of 9 Old 05-06-2016, 06:52 PM
Hey I've got another 89GT with an on3! Mines got a 76mm turbo and AFR heads, TFS stage1 cam, Holley systemax intake, I'm excited to see two successes with such a similar build. Mine will be on the road in a few days.
Blk.Snake and DreadFox like this.
post #9 of 9 Old 05-08-2016, 07:32 PM
mrjay1979's Avatar
100% stock block 85000 miles
f cam
ported twisted wedge
systemax intake
70mm on 3 kit, 9 lbs of boost 530/517
jpe and DreadFox like this.
mrjay1979 is offline
Fueling a 500 RWHP supercharged fox? BIGRIGS Superchargers 21 05-19-2013 04:44 AM
Which pulley for 15ish psi with S Trim SN95? Will this get me to 550ish rwhp? A9L ?'s Speeds8erM-1 Superchargers 48 12-21-2012 01:29 AM
For Sale 500 RWHP Procharged 1999 cobra. 11k OBO justa306 Mustangs For Sale/Wanted, 1999-2004 4 03-30-2011 12:13 AM
Near or past 500 rwhp w/a blown 306??? SN95LEEN 5.0/5.8 Engine Tech 11 12-17-2001 10:57 PM
Serious questions dilemma about mechanical oil PSI gauge and DOHC oil PSI readings Cobra Jet NJ GT & SOHC 11 12-14-2001 04:19 PM
