New turbo 76 to an 82 - Ford Mustang Forums : Corral.net Mustang Forum
 8Likes
  • 3 Post By TomR
  • 1 Post By KEVIN$
  • 1 Post By TomR
  • 1 Post By TomR
  • 2 Post By TomR
post #1 of 11 Old 02-11-2016, 08:26 AM Thread Starter
TomR's Avatar
The guy at the local turbo shop called it right.
He said I would gain 200-300 with the same boost by just by dropping backpressure with one of his custom ported S480's with a racing housing and that is what it did. It gained over 200, but we do not know exactly how much because we could not keep the tires stuck to the wheel very far over 1000.
This should bump me from 5.4 down to 5.1 or less if I can keep traction, which I'm real happy with in a quiet full interior car with power winders running though mufflers on Pro radials. I know this isn't the fastest car around, but this has been a lot of work so I am pretty happy.
I'm so happy, I decided to buy myself a crank trigger today and ditch the TFI dizzy.
kbscobravert, HLD-TYT and DreadFox like this.
TomR is offline
post #2 of 11 Old 02-11-2016, 02:29 PM
Nice! Which turbo shop, if you don't mind me asking?
MFT
DreadFox is offline
post #3 of 11 Old 02-11-2016, 06:57 PM
KEVIN$'s Avatar
CONGRATS, Tom!
That's some serious Go Fast power that should definitely increase the pucker factor!
ks
TomR likes this.
Kevin Slaby
KEVIN$ is online now
post #4 of 11 Old 02-12-2016, 12:46 AM Thread Starter
TomR's Avatar
A little shop up in Griffin GA. Nicolas Automotive Repair. They have a turbo shop and DynoJet Dyno. Yiyito has a room there where him and another fellow build turbos. It looks like a fairly good setup. They have a pretty big lathe and mill, and just dozens and dozens of turbos.
I think this is him
https://www.facebook.com/nicolasautorepair/timeline
Here is Nicholas in his RX7:
https://www.youtube.com/watch?v=KT0GxgvPu3I
I have a list of stuff now.
I need to take some BBW's off Craigslist to sit on my truck for traction.
I ordered a crank trigger system Thursday morning.
I have to move the radiator inlet somehow so I can get an air inlet system on the turbo.
I have to get the intercooler back down.
I probably should get rid of the factory style engine mounts, although the engine did not look like it rocked too bad.
I have a new rear end with spool and 35 splines with 9 inch ends. (Thanks for the tabs Kevin!) That will be my secret 8 lug setup.
Then I gotta go to a chassis shop and get some beefing up for the control arms.
Then I'll be ready to take on an LS.
DreadFox likes this.
TomR is offline
post #5 of 11 Old 02-14-2016, 01:50 AM
Nice. I've been looking but don't want to have to worry about my DP not lining up perfectly.
kbscobravert is offline
post #6 of 11 Old 02-14-2016, 10:19 PM Thread Starter
TomR's Avatar
Yeah, I cut my intercooler end off today, milled the end, and tack welded extensions in place to tilt and move the inlet for better alignment with the turbo outlet. I will TIG it up tomorrow.
The bigger turbo moved the turbo outlet a couple inches forward, so I have no choice but to move the IC inlet.
Race cars. Always work.
TomR is offline
post #7 of 11 Old 02-15-2016, 03:42 AM
Got a pic of it in yet?
You ready to delve into CNP? I'm using the Holley coils, crank triggER and an explorer cam sensor if you have any setup questions.
post #8 of 11 Old 02-15-2016, 08:45 AM Thread Starter
TomR's Avatar
Thanks, but I'm staying with my CD ignition and just using my Ford TFI dizzy as the spark router. I bought some kit with 36 teeth that uses a missing tooth as the locator, but I'm am not sure yet how that will work without a cam sensor. Maybe I can use the TFI as a cam sensor?
TomR is offline
post #9 of 11 Old 02-16-2016, 11:17 AM
blk91coupe's Avatar
Awesome you picked up that much. S480s are pretty great turbos. Congrads
What does your exhaust consist of? Mufflers?
blk91coupe is offline
post #10 of 11 Old 02-17-2016, 03:51 PM Thread Starter
TomR's Avatar
I'm going to make some test passes Saturday and get in a street class race Sunday. We will see if the dyno and tracks agree, although I'm nervous about my 33 spline Wavetrac and 4 lugs now. It was very consistent 5.4's ET before this change.
I just finished re-welding my intercooler inlet at a new angle so the IC can sit back on the cradle above the water pump, so I'm done except for swapping the rear end (spool and 35 spline 8 lug) and installing the crank trigger.
My exhaust goes from 4" under the car to a Y right by the trans tail shaft. The Y feeds to dual 3" to the dual Borola XS 3" mufflers with turn downs at the back axle.
TomR is offline
post #11 of 11 Old 02-25-2016, 08:20 AM
is the tire spinning on the rollers or is the wheel spinning inside it? if the former, use that track bite! If the latter, time for bead locks.
5.0thunder is online now
For Sale MMR 2V, 3V & 4V Custom Cams -Supercharger, Turbo, N/A & Nitrous, Stroker & 5.4 grinds Mod Mustang Racing Modular Engine Parts 74 12-29-2015 11:48 AM
2005-2010 Mustang GT Intercooled Single Turbo System Granatelli Turbochargers 71 12-18-2012 07:16 AM
For Sale 03 DSG Twin Turbo Gt. Driver500 Mustangs For Sale/Wanted, 1999-2004 10 08-21-2012 11:47 PM
For Sale COMPLETE SBF Turbo Kit: Polished PT8847-H 1200 RWHP T4, A2W, Exhaust! CHECK IT OUT! Turbo308 Power Adders 4 10-05-2011 03:24 PM
For Sale Hellion Power Systems 96-04 Mustang Twin Turbo Kit *SALE* PowerAdder Solutions Power Adders 1 05-11-2011 01:32 PM
