Wastegate selection - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 01-26-2016, 02:59 PM Thread Starter
Wicked03GT's Avatar
Trader Feedback: (50)
Wastegate selection
Been trying to keep this as low kay as possible but im in a field im not super familiar with and im to the point now where I have to order some parts for building my hotside.
408w
10:1 compression
Garrett GT4202
https://turbobygarrett.com/turbobyga...charger#GT4202
I know im going to need either a single large wastegate like the precision 66mm, or I could also run dual smaller gates like the 39mm units. Is their a benefit to running one or the other? THe price is near identical.
Also, should I be concerned with the size of my BOV? I not some are in the 40-50mm range and the precision is a 64mm unit.
Wicked03GT is offline
post #2 of 5 Old 01-26-2016, 03:38 PM
KEVIN$'s Avatar
What does the hot side piping and merge look like? Do the two pipes merge at the turbo flange or farther away leaving a long collector?
ks
Kevin Slaby
KEVIN$ is offline
post #3 of 5 Old 01-26-2016, 10:41 PM Thread Starter
Wicked03GT's Avatar
They have not been fabricated yet, but they are going to be a shorty header style setup near identical to the BG or the CG Fab pieces that are available.
post #4 of 5 Old 01-27-2016, 10:13 AM
KEVIN$'s Avatar
From what Ive seen/read if both headers merge into one longer pipe before the turbo then one large WG can be used to vent that one pipe. If both headers merge directly at the turbo flange then two smaller WGs are needed to vent each pipe.
ks
Kevin Slaby
KEVIN$ is offline
post #5 of 5 Old 01-27-2016, 01:28 PM Thread Starter
Wicked03GT's Avatar
I found a deal on a brand new Boosted Solutions gate that is a 66mm unit, I think im going to pick it up.
On3 wastegate placement BERT306 Turbochargers 7 07-11-2015 10:22 PM
For Sale Tial 60mm wastegate and jgs 60mm wastegate 94GtVert50 Power Adders 3 01-07-2014 09:08 PM
On3 Dual Wastegate Overboosting Issue MTBSully Turbochargers 11 12-08-2013 10:43 PM
SOLD Turbonetics Racegate wastegate WG Swiftshifter Completed Sales 1 10-26-2012 02:22 PM
Want To Trade Turbo smart Pro-gate 50mm wastegate sonic 02 Power Adders 1 08-14-2012 09:28 PM
